Mustang Forums at StangNet
'02 Ford Ranger Door locks not working problem...
This is a discussion on '02 Ford Ranger Door locks not working problem... within the Other Auto Tech forums, part of the General Automotive Forums category; '02 Ford Ranger... I know this is "5.0" but i have a small problem with my daily driver and seeing ...
Go Back   Mustang Forums at StangNet > General Automotive Forums > Other Auto Tech
Over 151,000 Members!!
Reply
  #1 (permalink)
Old 06-03-09, 05:18 PM
'02 Ford Ranger...
I know this is "5.0" but i have a small problem with my daily driver and seeing as its atleast a Ford vehicle i thought i'd get by with this thread!? Anways... My problem is the keyless entry unlock and lock does not work, neither does the panic button. Second, my drivers side door lock/unlock button does not work. But my passenger side door lock/unlock button does work. And both doors lock and unlock when you use the passenger side switch. So what is the default here? Is the switch bad? Why don't my keyless entry buttons work? Any help would be greatly appreciated!!! Thanks
  #2 (permalink)
Old 06-03-09, 06:26 PM
Darkwriter77's Avatar
Resident Ranting Negative Nancy
Might be two separate issues. I'd try changing out the battery in the keyless entry remote first (and clean the battery contacts) and see if that helps before you go ripping the door panel off to mess with switches.
  #3 (permalink)
Old 06-03-09, 11:46 PM
I'll get a new battery for the keyless entry control. But doesn't it have to be the switch then if the drivers side switch doesn't work?
Reply
Thread Tools
Rate This Thread:
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
