Mustang Forums at StangNet
07gt with boost issue
This is a discussion on 07gt with boost issue within the 2007 - 2009 GT500 Tech forums, part of the 2005 - 2009 (S-197) Mustang category; Just picked up a 07 GT five speed with a Saleen Stage 1 blower. That was put on by JDM ...
Go Back   Mustang Forums at StangNet > Mustang Forums > 2005 - 2009 (S-197) Mustang > 2007 - 2009 GT500 Tech
Over 151,000 Members!!
Reply
  #1 (permalink)
Old 06-06-09, 11:38 PM
89hatchlx's Avatar
Question 07gt with boost issue
Just picked up a 07 GT five speed with a Saleen Stage 1 blower. That was put on by JDM Engineering in Jersey. Day one boost hit 8 psi no problem held steady untill you let off the gas day two hardly wants to hit 4 psi and the boost gauge flutters like a butterfly. Car still seems to be running great but it just weird i know it should hold steady... Anyone have and ideas or info on what i can do to fix or check? All help is greatly appreciated... Thanks
  #2 (permalink)
Old 06-29-09, 02:59 PM
lx93notch's Avatar
it could be possible that you have some belt slippage goin on there, thad be the first thing to check along with the tensioner
  #3 (permalink)
Old 06-29-09, 07:57 PM
stangzilla100's Avatar
Official Member
belt slip is probly the culprit. hows the a/f and the fuel pressure?
  #4 (permalink)
Old 07-01-09, 11:00 AM
whitegt500's Avatar
another problem may be if they didnt upgrade the spark plugs and may be blowin out the spark under hard acceleration, i have my plugs gapped at .30 and anything over .35 maybe causing that
  #5 (permalink)
Old 07-10-09, 08:58 PM
My06Stang's Avatar
You should pull the plugs and make sure they are the colder HT0 not the stock motorcrafts. the other thing would be to check the color of the injectors they should be BLUE at least. those are generally the cobra injectors so it makes sure you have pleanty of fuel.
Belt slip could be the issue also just a loose boost line if it is not electrical. the saleens use a sender for that stuff so it could be bad.
you should have a shop check it out.
Reply
Thread Tools
Rate This Thread:
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
