Mustang Forums at StangNet
radial and bias ply
This is a discussion on radial and bias ply within the MII Discussion forums, part of the Mustang II category; This may be a dumb question but if you have radials on the front of your car and you ran ...
Go Back   Mustang Forums at StangNet > Mustang Forums > Mustang II > MII Discussion
Over 151,000 Members!!
Reply
  #1 (permalink)
Old 06-09-09, 06:34 AM
Official Member
radial and bias ply
This may be a dumb question but if you have radials on the front of your car and you ran bias ply dot slicks on the back is that ok to do? Any problems? Can this be used on the street or is the car going to act weird because of the 2 differant tires on it?
  #2 (permalink)
Old 06-09-09, 08:35 AM
Official Member
The tire construction difference can cause handling problems. I do not recommend doing this.
GT
  #3 (permalink)
Old 06-09-09, 11:10 PM
Dano78's Avatar
Agreed.
Unless you have a purpose for running the mix-matched set, try not to. Running Radials in the front and Bias Plys in the rear is not as bad as doing the opposite- i.e. bias plys on the steer axle with radials pushing it, will seem like the front end is on ice. Radials conform to the uneven roadway so much better than a bias ply will. But if you're just hot doggin to the track and back, as long as you can handle a loose rear, you should be fine.
  #4 (permalink)
Old 06-10-09, 06:41 AM
$50COBRAII's Avatar
Not a big deal
The main concern of mixing would be mixing of the two types on the same axle. With the soft sidewall of slicks its going to feel different anyway, and its not like your gonna go slicing through a road course anyway.
  #5 (permalink)
Old 06-10-09, 02:58 PM
Official Member
Quote:
Same axle is what I thought too. The radials are cheap for the front 120 for the pair compared to 120 each for mt front runners. I was going to run drag radials but I may want to go with slicks so I just wanted to see everyones experiance with it. Thanks for the reply.
  #6 (permalink)
Old 06-10-09, 03:03 PM
Official Member
I thought the radials are much more narrower then the bias plys thats another reason I did it.
Reply
Thread Tools
Rate This Thread:
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
