Mustang Forums at StangNet
Driveshaft
This is a discussion on Driveshaft within the MII Discussion forums, part of the Mustang II category; For a T-5 swap did you guys use the stock II driveshaft or did you have to add 2inches to ...
Go Back   Mustang Forums at StangNet > Mustang Forums > Mustang II > MII Discussion
Over 151,000 Members!!
Reply
  #1 (permalink)
Old 06-09-09, 07:13 AM
Official Member
Driveshaft
For a T-5 swap did you guys use the stock II driveshaft or did you have to add 2inches to it? Infact my car was an auto before is that drive shaft the same as the 4spd or are they differant? I went to get my driveshaft balanced yesterday and the guy said it looks alittle short he seen the rub marks from the seal and it should be in more. He said that would cause vibration at higher speeds. It does vibrate at 60 and up not to crazy but noticable. I dont even know if I have the right driveshaft in the car.
  #2 (permalink)
Old 06-09-09, 07:40 AM
Official Member
I would like to try the ford racing one.
  #3 (permalink)
Old 06-09-09, 08:03 AM
For a T-5 swap, you have to cut 2 inches off the stock (manual) driveshaft. I don't know about the driveshaft in an automatic. The driveshaft yoke should stick out some from the transmission otherwise when the rearend articulates it will bind up.
david
  #4 (permalink)
Old 06-09-09, 11:12 PM
Dano78's Avatar
Could have sworn that the C4 driveshaft was 1.5" shorter than the RAD 4 speed driveshaft. See if I can find one in the pile to measure.
  #5 (permalink)
Old 06-10-09, 03:11 PM
Official Member
I measured it and got 46 inches. I went back to the guy and we measured the driveshaft and it was 46 inches so I dont know what the hell happened.
  #6 (permalink)
Old 06-11-09, 04:08 PM
Steel Steeds's Avatar
Official Member
Quote:
That depends on which bellhousing you use. 2" sounds right with the II bell, I only had to take 1" off of my driveshaft using the Fox body bellhousing.
  #7 (permalink)
Old 06-12-09, 06:23 AM
Official Member
I am using the fox bellhousing also. The guy told me the yoke shoulder has to be 1inch away from the trans and thats what it is.
Reply
Thread Tools
Rate This Thread:
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
