Mustang Forums at StangNet
AFR vs ECT
This is a discussion on AFR vs ECT within the 94-95 5.0 Tuning forums, part of the 94-95 Tech category; Whenever I change the AFR to 14.7 at idle and low load the ECT increases to about 220* vs 195* ...
Go Back   Mustang Forums at StangNet > Mustang Forums > 5.0 Mustang > 94-95 Tech > 94-95 5.0 Tuning
Over 151,000 Members!!
Reply
  #1 (permalink)
Old 06-15-09, 09:15 PM
toyman's Avatar
Official Member
AFR vs ECT
Whenever I change the AFR to 14.7 at idle and low load the ECT increases to about 220* vs 195* at AFR 14.0. Ambiant air temp is about 80*. Does this make sense? Low fan is on at 190* and high at 220*. I know that the leaner burn will be hotter but this seems out of whack. I'm using 94 octane fuel if that makes a difference. Not certain if timing is also a variable in this equation.
Reply
Thread Tools
Display Modes
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
