Mustang Forums at StangNet
questions on my gt500
This is a discussion on questions on my gt500 within the 2007 - 2009 GT500 Tech forums, part of the 2005 - 2009 (S-197) Mustang category; how can u tell what size a metco pullie is? is there a # or sumthn in or around the ...
Go Back   Mustang Forums at StangNet > Mustang Forums > 2005 - 2009 (S-197) Mustang > 2007 - 2009 GT500 Tech
Over 151,000 Members!!
Reply
  #1 (permalink)
Old 06-18-09, 11:08 PM
whitegt500's Avatar
how can u tell what size a metco pullie is? is there a # or sumthn in or around the pullie, car came with it already
  #2 (permalink)
Old 06-19-09, 07:43 PM
There are 2. One is a 2.8 that is a 10lb pulley and the 2.6 that is a 12lb pulley. Check your psi gage at about 5k and full throttle and you should be able to make out which one it is. I'm guessing it's the 2.6. I would hope there is also the extra tensioner pulley on there with it.
  #3 (permalink)
Old 06-19-09, 09:13 PM
whitegt500's Avatar
ill check it out
alright man thanx ill have to see what it reads at that rpm range, it doesnt seem to have a aftermarket tensioner so ima make it my next step to put that on
  #4 (permalink)
Old 06-20-09, 12:37 PM
They do also make a stock size one. I didn't even think about that. I have one sitting on my desk here. It has no part numbers on it. If there is no extra tensioner it's possible to have a stock one I guess.
  #5 (permalink)
Old 06-20-09, 12:40 PM
Here is a picture of the 2.6 and the tensioner
  #6 (permalink)
Old 06-26-09, 07:17 PM
whitegt500's Avatar
Quote:
yea i need to put that tensioner on definately, what tensioner did u buy for yours? or do they all seem to work the same
  #7 (permalink)
Old 06-26-09, 09:42 PM
  #8 (permalink)
Old 06-30-09, 10:13 AM
Quote:
I would measure the front of it and then take about .2" off as the aftermarket pulleys are measured by the peaks of the ribs.
I would not go by the boost guage as that is not terribly accurate.
  #9 (permalink)
Old 07-10-09, 09:24 PM
My06Stang's Avatar
Thats true someone may have put a stock size on to trade it in since they wouldnt want to press on the stock pullie as most times its trashed pulling it off.
Reply
Thread Tools
Rate This Thread:
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
