Mustang Forums at StangNet
Suspension sounds like an old recliner...Creak Creak!??!
This is a discussion on Suspension sounds like an old recliner...Creak Creak!??! within the V6 Talk forums, part of the 94-04 V6 Mustang category; I have replaced my lower ball joints and have greased them and after a day of driving it sounds like ...
Go Back   Mustang Forums at StangNet > Mustang Forums > 94-04 V6 Mustang > V6 Talk
Over 151,000 Members!!
Reply
  #1 (permalink)
Old 06-22-09, 10:33 AM
I have replaced my lower ball joints and have greased them and after a day of driving it sounds like it did before but only on one side..WTF Any suggestions to where this sound is coming from? Thanks.
  #2 (permalink)
Old 06-23-09, 09:39 AM
MustangLX-5.0's Avatar
When does the creeking sound occur? Does it happen more frequently when you turn your steering, or maybe when you are hitting bumps and uneven road surfaces? I've never heard ball joints creek before. You most likely never had bad ball joints and probably have another suspension/steering issue. Could be a strut mount loose, or it could also be the steering rack mounts. I'm thinking the steering rack may be a little loose. The metal sleeves will create creeking noises and eventually become a constant "creek ...creek creek" especially when turning the steering wheel. Tightening the rack bolts/nuts just a little may fix this. I can't go into further details unless I know a little more about the noise your describing.
  #3 (permalink)
Old 06-23-09, 10:13 AM
Thanks for the input. I have replaced the steering rack roughly 6 months ago but I will check to see if it needs to be tightened. The sound happens whenever I go over even the slightest bump or uneven surfaces. I don't believe the steering has anything to do with it. I just dont want to start replacing parts that I do not need to. Wallet cant handle it.
Reply
Thread Tools
Display Modes
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
