Mustang Forums at StangNet
78' MUSTANG II, WHEEL & TIRE SIZE ?
This is a discussion on 78' MUSTANG II, WHEEL & TIRE SIZE ? within the MII Discussion forums, part of the Mustang II category; HI EVERY ONE, OK so the question is: What is the origonal tire size for a 1978 Mustang II. The ...
Go Back   Mustang Forums at StangNet > Mustang Forums > Mustang II > MII Discussion
Over 151,000 Members!!
Reply
  #1 (permalink)
Old 06-26-09, 05:10 PM
95-gts-rocket's Avatar
Question 78' MUSTANG II, WHEEL & TIRE SIZE ?
HI EVERY ONE,
The tire sizes on the car now are (P185/70 R13)&(P185/80 R13). I supect thes are pretty close. What is intended is to use the 10 spoke alimnium 4 lug from a 1985 Mustang GT. For the newer 10 spoke I plan to use eather (P205/60 R15) or
(P195/60 R15). I know some has tryed this because I have seen photos of a MII with those mags on it. I need the information for tire size calculation.
I hope this stuf makes sence ? Thanks.
  #2 (permalink)
Old 06-27-09, 06:57 AM
76_Cobra_II's Avatar
Official Member
At the top of the page is a large thread about different tires sizes that will fit. I would look at that and see if it helps you out any.
  #3 (permalink)
Old 06-27-09, 10:32 AM
welder4956's Avatar
Official Member
Stock tire size was B78-13 bias ply and either BR78-13 or BR70-13 radials. Optional size was 195/70R13. You probably won't find any of those sizes on the market today, but you can find a 14" or 15" tire size that works by checking the thread that Sean referred to.
  #4 (permalink)
Old 06-29-09, 11:15 PM
Dano78's Avatar
Quote:
They are still out there. Matter of fact BFG still makes that size as well as a few others that some have thought were long vanished.
  #5 (permalink)
Old 06-30-09, 06:42 AM
Official Member
I ran ten holes on my car for 2 years. The set up was 225/60/15 all around I did use 1/4 inch spacer in the front. I think the situation was the rim would rub on the upper A arm in turns. Maybe trimming the stock A arm or a new tubular one would clear I just did the easy thing the shim spacer. I currently run turbines with one inch bolt on spacers all around tires 225/60/15 in front and 235/60/15 in back. Working on the new setup now rodlites 15X3.5 front and 15X8 rear.
Reply
Thread Tools
Rate This Thread:
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
