Mustang Forums at StangNet
98 cobra stalls when hot or humid outside
This is a discussion on 98 cobra stalls when hot or humid outside within the SVT Tech forums, part of the SVT category; my car has been stalling when its hot outside it will start to idle down and will have no throttle ...
Go Back   Mustang Forums at StangNet > Mustang Forums > SVT > SVT Tech
Over 151,000 Members!!
Reply
  #1 (permalink)
Old 06-27-09, 09:38 AM
my car has been stalling when its hot outside it will start to idle down and will have no throttle response and act like its starving for something but if i sit there for a min it will fire up and drive again then basically repeat itself i know it has to do with the heat messing with something cause at night i can cruise around for hours problem free any advice?
  #2 (permalink)
Old 06-27-09, 11:19 AM
jeremy canter's Avatar
Official Member
Garage
check your fuel psi > it might not be the heat affecting the motor >but the pump getting hot during the hot hours of the day and shutting off>
  #3 (permalink)
Old 06-27-09, 07:51 PM
so would that mean the pump is bad or what? if thats the case could it be the fuel pressure regulator?
  #4 (permalink)
Old 06-28-09, 09:01 PM
Official Member
Garage
unless you got the money to just throw parts at it > wait >we need to find the problem first then upgrade > if you just put parts on it you never know what it was that is giving you problems > incase it come's back down the road > It might not have anything to do with the fuel at all > find a fuel guage and watch you fuel psi > if it looks screwy or weak then try to find a fuel psi reg > hopefully someone has a nice after market one cheap > most of the time it's your pump not the reg > but if you do have to put a pump in your car > buy new > gas tanks suck > and if you can swing it > up grade to a larger pump (more flow)
Reply
Thread Tools
Display Modes
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
