Mustang Forums at StangNet
GT 5.0 Bored .30 Over and Car Built. Whats your HP Guess???
This is a discussion on GT 5.0 Bored .30 Over and Car Built. Whats your HP Guess??? within the 5.0 Talk forums, part of the 5.0 Mustang category; Hi there guys, wanted to see what you thought about a car im buying and what HP ratings you think ...
Go Back   Mustang Forums at StangNet > Mustang Forums > 5.0 Mustang > 5.0 Talk
Over 151,000 Members!!
Reply
  #1 (permalink)
Old 07-01-09, 04:22 PM
Official Member
Garage
Talking GT 5.0 Bored .30 Over and Car Built. Whats your HP Guess???
Hi there guys, wanted to see what you thought about a car im buying and what HP ratings you think will be produced.
MOTOR
302-.30 over
8:1 compression
Hastings rings .17 top, .15 bottom
Tall Ford Racing valve covers-black
Edelbrock Performer RPM aluminum heads
7/16 head studs w/ 1/2 spacers
Ford Motorsports 1:6 aluminum roller rocker arms
Hardened push rods
BBK long tube headr and H-pipe
Mac flow path 2 & 1/2" mufflers
Comp roller cam
30 lb. injectors
Mac gear drive timing
ProFlow mass air meter
70mm throttle body
Ford idle air adjuster spacer
Milodon 7-quart oil pan with windage tray
GT-40 lower intake w/ Car tech upper (extruded/honed)
High volume oil pump w/ hardened drive shaft
ProCharger P600 9-14 psi w/ 2-core intercooler
MSD 6 boost timing master ignition
MSD Blaster TFI coil
BBK adjustable fuel pressure regulator
1901ph fuel pump
Potima battery
140 amp alternator
16 inch electric fan pulling/14 inch electric fam pushing
AFCO 2-core aluminum radiator
DRIVE TRAIN:
Adjustable clutch cable and quadrant
Tremec TKO tranny
Ram clutch
8.8 rear end (Strang 3.73 gears)
5-lug disc brake conversion
Guages:
200 mph white face gauges
AutMeter monster tach w/ shift light
2/16 boost gauge
2 & 5/8 mechanical fuel pressure gauge
2 & 1/16 air/fuel ratio gauge
Dual gauge pod on A-pillar
Chassis:
8-point rollcage
Cross bar subframe connectors
Factory 5 lower and upper control arms
Lower Wild Rides battle boxes
Sallen strut tower brace
17 x 9.5 rims
205/40R17 front tires
275/40R17 street drage radials
Thats the Build Give your input Please.....
  #2 (permalink)
Old 07-01-09, 04:26 PM
93 5.0 GT's Avatar
Looks like one hell of a nice ride
Horsepower numbers depends on cam specs and boost pressure
id say over 400 to wheels since it has 8 to 1 compression and can take more boost because of it
  #3 (permalink)
Old 07-01-09, 08:04 PM
Cobra912's Avatar
Official Member
not much on the fuel side of things...........I would say 380-400 at crank. But that's a guess.
  #4 (permalink)
Old 07-02-09, 07:51 AM
25thmustang's Avatar
Official Member
Call me a dick, but did you build this, or did you get the info out of a catelogue and ask us what it would make?
I agree, lack of fuel might be an issue...
  #5 (permalink)
Old 07-04-09, 01:11 PM
Official Member
This car is a built car that im going to buy. The Owner built the car from ground up. I notice that you guys talk about the fuel. What can i do to upgrade the fuel, say maybe just bigger injectors (50lb) and say a 255lph in-tank pump instead of the 190. Any suggestions????? This car does exist. Do you think its a good built engine??????????????
  #6 (permalink)
Old 07-04-09, 03:02 PM
old_blue's Avatar
Official Member
I agree with 25thmustang but to answer your question:
I would say add a 255 f/p, Fuel pressure regulator, I am assuming you already have a calibrated maf for the 30lbers? I dont think anymore than the 30's is needed IMO
  #7 (permalink)
Old 07-04-09, 03:37 PM
Official Member
{Call me a dick, but did you build this, or did you get the info out of a catelogue and ask us what it would make?}
Is the engine build not good and whats do you guys mean by this statement?
Also you mentioned a Pressure regulator / or do you mean a 255lph intank pump?
Thanks Matt
  #8 (permalink)
Old 07-04-09, 04:09 PM
Cobra912's Avatar
Official Member
well in my opinion the engine would be fine with the 30's and the 190 pump. However I would think you may be pushing it with the blower as the demand for fuel goes with boost. I woulkd personally run a 42 or bigger injector as well as a minimum of a 255lph HO pump. I'm running both of these on my 331 with a Paxton 1220SL seeing abouth 7lbs of boost.
I couldn't find the chart but if you search these forums you will be able to see the recommended injector for horsepower levels.
  #9 (permalink)
Old 07-04-09, 04:11 PM
Cobra912's Avatar
Official Member
oh also is it tuned with a chip or other device or is it running an fmu?
  #10 (permalink)
Old 07-04-09, 04:19 PM
Official Member
I think it has a FMU!!!!!!
  #11 (permalink)
Old 07-04-09, 09:48 PM
Cobra912's Avatar
Official Member
If you bought it I would ditch the FMU too and get a tune from a reputable shop / tuner.
  #12 (permalink)
Old 07-05-09, 06:58 AM
Official Member
I have a post on the 5.0 Tech articles here now, looking for a tuner tech that is willing to travell to the Bahamas, as this is where the car is. Have any ideas ???? I guess i should go with at least 50lb Injectors and (2) 255lph Pumps or simmilar just to be sure and safe.
Thanks Matt
  #13 (permalink)
Old 07-05-09, 07:35 AM
Banned
OK it NEEDS atleast 42's and 255 intank 255 inline. It doesnt NEED a regulator but it would be nice. A tune is also needed throw that fmu in the trash. I would expect nothing less then 450 rwhp, should be more though. Put some front tires on the thing too.
  #14 (permalink)
Old 07-05-09, 08:02 AM
84t-top's Avatar
Official Member
Quote:
x2 - exactly what i was going to say
  #15 (permalink)
Old 07-05-09, 11:05 AM
Official Member
I Ordered some 50lb Injectors and 1 in tank 255lph Pump and a Inline areomotive pump that flows 350lph. I Hope that will do it. I already have a Bigger Fuel Rail and a Pressure Regulator. Im trying to have the Car Tuned as well.
Any more forseen issues guys???
  #16 (permalink)
Old 07-05-09, 03:50 PM
Banned
Sounds like it should be up to par to me. Will make good power, blower cars are fun.
  #17 (permalink)
Old 07-05-09, 07:38 PM
Official Member
Thanks Guys for all the input, Thanks for helping me geting me on the right track.
I will post times etc once tuned.
  #18 (permalink)
Old 07-07-09, 07:36 AM
blackened88lx's Avatar
Official Member
Yea, what Bentley said. Sounds like you're on the right track. 50s and a 255 will be enough fuel to make enough power to split the block. Hopefully you go to a tuner that knows what he is doing. With that low of compression you will be able to crank up the boost and run a ridiculous amount of timing. There's no reason you should leave with less than 450-500rwhp unless you want the block to stay together, but that's no fun, live a little.
  #19 (permalink)
Old 07-07-09, 07:39 PM
Official Member
Anyone heard of a guy named Greg at Speedy Dyno in Owensboro KY. This is where its going and he will be using a SCT Tuner.
Anyone have used him before or any good things heard about him??????
  #20 (permalink)
Old 07-08-09, 12:01 AM
91ghp5.0's Avatar
Official Member
Run a google search. Ask about his experience with pushrod cars, smallblock Ford's especially.
  #21 (permalink)
Old 09-10-09, 04:37 PM
Official Member
Hey Guys, Got the car Tuned at Speedy Dyno, oh yeah that guy Greg hes just Great to work with and i highly recomend him, they are located in Owensboro. Ok remember the run down at the top of the post where i explained the details of the Motor, well let me start by saying be careful when you buy a car thats claimed to be built by a great car builder, especialy if you cant google his name and cant come up with one article.
First it took over a month to get the car finish (Not actual working time / on and off) due to a stupid gear timing set (the ones that dont use a chain but gears instead) never use them, they are GARBAGE i swear, that the builder put in the car. Also the guy (Engine Builder) used Hypereutectic Pistons in the Block instead of Forged Internals (Dumb Azz), so the Boost was only turned up to 7.5 psi to make sure they would survive.
Well heres the Run Down, after changing the Timing gear to chain, Greg moved onto the fuel and spark, Swaped the 30lb injectors to 42's (Ford) and changed the MAF and piping that came from the fire wall to the Throttle body (the builder had all sorts of 90* angles in the one he had there), Greg changed it to a more free flowing sweeping mandrel bent pipe (better air flow). After putting in a Holly Fuel Pump cable of handling 700HP and installing a SCT Tunner with 3 Custom Tunes 1- Valet Tune for car rapist
2-Pump fuel street use and 3-Race Tune Race fuel used.
After the Dyno he pulled 397WHP and 392 Torque, he tried adding more timing but stoped at 19* as when he tried adding 2* more the HP backed down. So He Stoped at that, what do you guys think? I am satisfied considering the Block ratings (even though i would of liked to get a bit closer to the 550 Block HP).
Please Tell me What you Guys Think of my New Car Now.
  #22 (permalink)
Old 09-10-09, 05:21 PM
rbonella's Avatar
Official Member
Let see some pics. Is it a 93? Too bad you have those pistons/block. with that compression, you could make that blower scream!
  #23 (permalink)
Old 09-10-09, 09:09 PM
Official Member
This what she Looks Like, have more Pics will upload them latter.
  #25 (permalink)
Old 09-10-09, 09:32 PM
5.0Droptop's Avatar
Neutered Member
any bigger pics?
Reply
Thread Tools
Rate This Thread:
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
