Mustang Forums at StangNet
cowl area
This is a discussion on cowl area within the MII Discussion forums, part of the Mustang II category; can you enter the cowl thru the hinges if you take them off? i have debris in there and i ...
Go Back   Mustang Forums at StangNet > Mustang Forums > Mustang II > MII Discussion
Over 151,000 Members!!
Reply
  #1 (permalink)
Old 07-05-09, 12:18 PM
Talking cowl area
can you enter the cowl thru the hinges if you take them off? i have debris in there and i want to clean it.
  #2 (permalink)
Old 07-06-09, 03:58 PM
Wart's Avatar
I'm Mad as HELL and I'M not Gonna Take it ANYMORE!
Yes, limited access.
Don't damage your boots.
  #3 (permalink)
Old 07-06-09, 08:54 PM
you can go through the fenders too. I have an air blower attachment for the compressor that has a small tube that fits between the grates on the cowl and blow like hell.
  #4 (permalink)
Old 07-07-09, 08:06 AM
Talking
i have a hose that will fit from my vacuum cleaner that i can use. i just wanted to be sure i could access this after i remove the hood and hinges or just the hinge and pockets. thanks alot
  #5 (permalink)
Old 07-07-09, 09:58 AM
Wart's Avatar
I think you get better access by removing the heater box and vents ....
  #6 (permalink)
Old 07-07-09, 11:06 AM
COBRAIIW's Avatar
Official Member
Quote:
If you look waaaay up in the upper corner of the fenderwell, after you remove the inner plastic fender, you will find an opening that you can stick a small diameter vacuum hose into.
Reply
Thread Tools
Rate This Thread:
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
