Mustang Forums at StangNet
Dyno number results with new combination
This is a discussion on Dyno number results with new combination within the Mach 1 forums, part of the Special Production category; Here are the results of the dyno tune I had done. I am trying to get low 12's or if ...
Go Back   Mustang Forums at StangNet > Mustang Forums > Special Production > Mach 1
Over 151,000 Members!!
Reply
  #1 (permalink)
Old 07-07-09, 12:53 PM
Here are the results of the dyno tune I had done. I am trying to get low 12's or if all the stars are aligned I would like to get into the high 11's. Not sure if that will happen but will try. Best so far was 12.64 and that was with 300hp!
Dyno numbers: 362 SAE HP & 334 SAE Torque.
Mods 2003 Mach 1
Comp Cams Part#106400
Roy's Ported & Polished Lower Intake
PHP Intake Spacer
Accufab TB
SLP Longtubes
SLP Catted X pipe & SLP Catback
Steeda CAI
4.10 gears
Zoom Clutch
Zoom Aluminum FW
Dyno tuned by Alternative Auto Performance
  #2 (permalink)
Old 07-29-09, 06:09 PM
man, thats some great numbers! its probably a lil higher cuz of the gears tho!
  #3 (permalink)
Old 07-30-09, 09:20 AM
Quote:
Thanks, not sure what you mean about the gears. The higher ratio gears usually means lower numbers. That is what I have always gone by.
No matter the gears or the numbers the car really woke up at higher rpm's and sounds great. Thanks again.
  #4 (permalink)
Old 09-07-09, 09:44 PM
How can i get in contact with roy?? I need my intake ported and cant get ahold of naz.
  #5 (permalink)
Old 09-30-09, 01:58 PM
CatmanJJ's Avatar
Captain Tangnet
I think they're higher more so because of the cams.
I have stock 3.55 gears with same cams close and similar dyno numbers so I doubt gears have much effect.
Quote:
Nobody can get a hold of Naz and I wouldn't bother until he sorts some personal stuff out, that's my take based on some recent drama I've read about...that being said Roy is on the M1R.
  #6 (permalink)
Old 10-11-09, 01:19 AM
gears dont effect hp they are just a torque multiplier
  #7 (permalink)
Old 10-29-09, 08:56 AM
Quote:
Thanks for the comments.
  #8 (permalink)
Old 10-31-09, 08:29 AM
1BADAOD's Avatar
Good numbers!
Reply
Thread Tools
Rate This Thread:
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
