Mustang Forums at StangNet
Should I just disconnect the dash speakers?
This is a discussion on Should I just disconnect the dash speakers? within the Sound Shop forums, part of the Mustang Sound & Shine category; For anyone that owns a Fox-body Mustang, you will be aware of the 3-1/2" speakers located at the top corners ...
Go Back   Mustang Forums at StangNet > Mustang Forums > Mustang Sound & Shine > Sound Shop
Over 151,000 Members!!
Reply
  #1 (permalink)
Old 07-10-09, 11:38 AM
Aftrbrnr's Avatar
Whitey cashier gave me the wrong change at the supermarket today.
For anyone that owns a Fox-body Mustang, you will be aware of the 3-1/2" speakers located at the top corners of the dashboard. My are getting kind of worn-out from age and I was wondering if I should even bother replacing them. Here are a few reasons why:
1) I've noticed that there are quite a few car audio manufacturers that don't make 3.5" speakers any more.
2) The few that are still on the market seem to have a continuous power rating (RMS) too high to be effectively powered by almost all aftermarket head-units (as in the built-in amp in them) but a max power rating so low that even the least powerful amps in most manufacturer's line-ups will blow them. Therefore, if I run them off the deck I can expect distortion since they're being underpowered but I run the risk of blowing them by hooking them up to an amp too powerful for them to handle.
I've also figured out dash-speakers aren't really the optimal imaging spot, and the door panel speakers are probably the most important ones in the entire car since the rear speakers in most vehicles are used for fill.
So in conclusion, I was thinking of just disconnecting them. My head unit has some sort of fancy "DSO" function which is supposed to make the speakers sound like they're up by your head but the function was intended for the door speakers and the dash speakers seem to get in the way of that. Anyone think this is a good idea?
  #2 (permalink)
Old 07-16-09, 11:22 PM
bynummustang's Avatar
Seen my other Jackstand?
Its been way too long since I've been in a fox with a radio to tell you. When I had it in mine, I had RF punch speakers in the door, dash, and back seat. They sounded great together.
What you're saying does make sense. What if you put a small resistor in series to the speakers, to lower the voltage if you run a small amp, or a cap for head unit.
  #3 (permalink)
Old 08-08-09, 12:02 PM
iskwezm's Avatar
Official Member
Theres plenty of replacement 3.5's still avail. Just use a 400 hz Bass Blocker to use them as a fill.We (PAC) have other cut offs avail too.
Reply
Thread Tools
Rate This Thread:
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
