Mustang Forums at StangNet
Oil Presssure Jumping Around
This is a discussion on Oil Presssure Jumping Around within the SVT Tech forums, part of the SVT category; I own a new to me 1997 Cobra, when I start it up the oil pressure reads just to the ...
Go Back   Mustang Forums at StangNet > Mustang Forums > SVT > SVT Tech
Over 151,000 Members!!
Reply
  #1 (permalink)
Old 07-14-09, 10:27 AM
I own a new to me 1997 Cobra, when I start it up the oil pressure reads just to the high side of the gauge mid-point, when I drive moderatly no change, when I start to rev up past 3500RPMs or so, the needle starts to jump around then move towards the low side of the gauge until I shift, then it goes back to normal and as I start to rev it goes through the cycle again. When I stop, the gauge sits right back at just to the high side of the mid-point...any idea what may cause this? Bad gauge? bad sending unit?
Thanks
  #2 (permalink)
Old 07-14-09, 12:01 PM
COBRA90GT's Avatar
Moderator
It's probably a sign that your sending unit it about to fail. Might also be a bad ground somewhere, but it's more than likely the sending unit.
The factory oil pressure gauges in these cars are nothing more than idiot lights and read about "halfway" as long as there is +/- 6 psi of oil pressure. They shouldn't bounce around or move.
I've had the factory oil pressure sender die and had to replace it as well - pretty easy task, maybe less than $12 for the part IIRC.
  #3 (permalink)
Old 07-14-09, 01:56 PM
I would assume (not to mention hope) it's the sending unit, the car seems to perform good at all RPM ranges so I'm hoping this is the all so elusive, easy and inexpensive fix!!
Reply
Thread Tools
Display Modes
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
