Mustang Forums at StangNet
New Mustang Steering Product
This is a discussion on New Mustang Steering Product within the Vendor Sponsor Forums forums, part of the StangNet News & Announcements category; What pitman arm does this piece use?...
Go Back   Mustang Forums at StangNet > StangNet News & Announcements > Vendor Sponsor Forums
Over 151,000 Members!!
Reply
LinkBack (10) Thread Tools Display Modes
  #26 (permalink)
Old 07-19-09, 01:47 PM
CraigMBA's Avatar
Official Member
  #27 (permalink)
Old 07-19-09, 05:24 PM
Quote:
the stock one, i'm assuming the stock one for power steering equipped cars, since it's a 16:1 ratio box, if you were to use the manual steering pitman i would think it throw off the ratio, at least at the steering wheel anyway.
  #28 (permalink)
Old 07-19-09, 05:54 PM
Is there any possibility of offering a discounted group buy to stangnet members?
  #29 (permalink)
Old 07-20-09, 07:41 AM
Borgeson's Avatar
Premium Sponsor
Quote:
Originally Posted by bnickel View Post
will this box work on other ford vehicles that use the same steering gear? for example; ranchero, torino, falcon, fairlane, etc ?
Thats up next, now that we have it in production for the Mustangs/Cougars we have started research to bring it to market for the other Fords / Mercs.
Thanks, Jeff
  #30 (permalink)
Old 07-20-09, 07:45 AM
Borgeson's Avatar
Premium Sponsor
It will fit with any stock 1" or 1-1/8" Pitman arm. (We offer the box in both sizes) The lenght of the Pitman arm will however still effect overall steering speed. The box is a 16:1 ratio with 4 turns of the Input shaft lock to lock, a longer Pitman arm will speed that up at the wheels.
Thanks, Jeff
  #31 (permalink)
Old 07-20-09, 07:47 AM
Borgeson's Avatar
Premium Sponsor
Quote:
Thats a tough one, we are a true manufacturer with an exisitng distribution network. We do sell all of our products direct however at full retail price to insure that our dealers an distributors can maintain the ability to make money on our products.
  #32 (permalink)
Old 07-21-09, 09:02 AM
Borgeson's Avatar
Premium Sponsor
An idea on pricing
And idea on pricing for complete kits below. The most affordable R&P conversion that is complete is $1,599 and again our box retains a stock look, simplified steering linkage (to the column), full turning radius and full ground clearance.
Quote:
Originally Posted by Borgeson View Post
1965-1966 Mustang (1” Diameter Sector Shaft)
Factory P/S Cars Require: $899
Power Steering Box
Power Steering Hose Kit
Steering Column Shaft / Floor Mount
Complete Rag Joint
65-66 V-8 M/S Center link
Manual Steering Cars Require: $1084
Power Steering Box
Complete Rag Joint
P/S Pump, Bracket and Pulley Kit
1967 Mustang (Must verify sector shaft diameter 1” or 1-1/8”)
Note: Cars with ¾” Diameter non-collapsible column shaft will require part #990040 Steering Column shaft/ floor mount and #052534 Complete Rag Joint not ½ rag joint.
Factory P/S Cars Require: $860
Power Steering Box
½ Rag Joint
Drag Link Adapter
Manual Steering Cars Require: $996
Power Steering Box
½ Rag Joint
1968-1970 Mustang (1-1/8” Diameter Sector Shaft)
Power Steering Box
½ Rag Joint
Drag Link Adapter
Power Steering Box
½ Rag Joint
  #33 (permalink)
Old 07-21-09, 03:28 PM
i might actually sell my TCP rack and use one of these or maybe i'll just put it on my other car
  #34 (permalink)
Old 07-31-09, 06:56 AM
Borgeson's Avatar
Premium Sponsor
Thumbs up Refund for original box.
Included with conversion box is a form to obtain a $65.00 refund if you send us your original manual steering box. Even with the cost to ship us the box this is another quick $50 of the cost of the conversion.
  #35 (permalink)
Old 08-03-09, 09:57 AM
pump question using 5.0 serpentine
I've got an '89 5.0 engine in my '66 with the serpentine setup. Would I have to adapt your pump or would the 89 model pump work?
  #36 (permalink)
Old 08-04-09, 08:24 AM
Borgeson's Avatar
Premium Sponsor
Quote:
Your 1989 5.0 pump should operate our conversion box just fine. I would need to know the high pressure fitting size on your pump to get you the proper hose kit.
  #37 (permalink)
Old 08-04-09, 01:01 PM
Borgeson's Avatar
Premium Sponsor
Dealers / Distributors
All part #'s for Mustang conversion are now good with Summit, Jegs, Motorstate, and Keystone. We are busy getting more on board as fast as we can.
Thanks,
  #38 (permalink)
Old 08-18-09, 05:32 PM
It has a nasty habit of removing the P/S hoses from the top of the box. The box itself clears but we cannot source any P/S fittings with a low enough profile to clear the hoses.
Even the Banjo fittings like sold by Pure Choice Motorsports are too tall?
  #39 (permalink)
Old 08-19-09, 07:42 AM
Borgeson's Avatar
Premium Sponsor
Quote:
Yes unfortunatley, we tried the banjo fittings and there is just no room to clear the Z-Bar.
Thanks, Jeff
  #40 (permalink)
Old 08-19-09, 08:30 AM
Do you have any photos of the Z-bar hitting the box/hose fittings?
  #41 (permalink)
Old 08-19-09, 08:38 AM
Borgeson's Avatar
Premium Sponsor
Didn't take any photos of it as it wasn't even close. With the box properly lined up to the column, the Z-bar crosses right over the top of the casting where the hoses enter the box. There wasn't any room for a fitting. I am sure one can (and will) modify the Z-bar to make it fit. This is possible but not something we as a manufacturer would really want to provide any instruction or guidance on.
Thanks, Jeff
  #42 (permalink)
Old 08-22-09, 07:11 AM
Official Member
what type if fittings are on the box im intrested in the box but have access to hose building equipment so i hate to buy hoeses that i can make
  #43 (permalink)
Old 08-24-09, 10:53 AM
Borgeson's Avatar
Premium Sponsor
Quote:
The fittings are 16MM flare fittings for both the pressure and return lines.
  #44 (permalink)
Old 08-24-09, 03:31 PM
Official Member
good that shouldnt be hard to find
  #45 (permalink)
Old 08-25-09, 09:05 AM
This is GREAT news.
I have 2 cars, both of which I haven't been driving because of the steering.
I was ready to spend the money this winter to swap in rack and pinions, boy I'm glad I waited!! I,ve been saying for years what a retarded P/S setup these cars have, I wish they had a box like the GM cars have..(corvette excluded)
When are thes available?
I have :
1966 vert with the 289/auto p/s.
1969 Mach1 351C/auto p/s.
Thanks....I'm so happy I could kiss you guys!!!
Kevin
  #46 (permalink)
Old 08-25-09, 09:31 AM
Borgeson's Avatar
Premium Sponsor
Quote:
Originally Posted by kevinmach1 View Post
This is GREAT news.
I have :
Kevin
Boxes are in stock and presently shipping. We offer both configurations you will need. 1" Sector for the '66 and a 1-1/8" for the 69. On a side note we fixed the 63-82 Corvette problem with a new box this year as well.
Thanks, Jeff
  #47 (permalink)
Old 08-30-09, 09:08 PM
Will be buying the complete PS setup this week
This set up is what I was looking for.
I plan to order the complete kit including Saginaw pump from Jegs this week and update the board on fit and clearance.
It will be installed in a 69" Mustang fastback,351w,automatic,non power steeering car. Hooker headers.
I spoke with Gil and got the part numbers for my application. Summit does not carry the parts
Gil Evans
Borgeson Universal Co.
91 Technology Park Dr.
Torrington, CT 06790
paul
Placed order tonight from Jegs Box in stock all other pieces(hose,coupler,saginaw) 4 day delay
  #48 (permalink)
Old 08-31-09, 10:13 AM
Thanks, Jeff
i have a question concerning the mustang and corvette boxes. basically i was wondering if the mustang box could be upgraded with the same 12.7:1 ratio as the vette box? they both appear to be based on a late model delphi 600 series box and i know the vette box, is the mustang box also based on the delphi 600 series box? any ratio that is better than the stock 15:1 on the mustang box would be great and i noticed your conversion box for the mustang still has the stock 15:1 ratio. is it even possible to change the ratio on your conversion box?
  #49 (permalink)
Old 08-31-09, 10:30 AM
Borgeson's Avatar
Premium Sponsor
With the core we are using for this conversion box changing the ratio is not possible. Internally the box is 4 turns lock-to-lock however on the car running bump stop to bump stop is only 3-1/2 to 3-3/4 turns.
  #50 (permalink)
Old 08-31-09, 11:36 AM
bummer, i was hoping we would have an option of a quicker ratio like at least in the 13:1 ratio or so. i like to be able to change lanes with a flick of the wrist...LOL, but thanks for replying so quickly
Reply
Thread Tools
Display Modes
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
LinkBacks (?)
LinkBack to this Thread: http://www.stangnet.com/mustang-forums/790455-new-mustang-steering-product.html
Posted By For Type Date
Any Experience With ABS Power Brake Inc??? - Mustangsandmore.com Forums ~ Friendly Forums for the FoMoCo Faithful This thread Refback 09-30-09 02:54 PM
Borgeson Integrated Power Steering Gearbox - Classic Cougar Forums This thread Refback 09-18-09 02:52 PM
Borgeson Integrated Power Steering Gearbox - Classic Cougar Forums This thread Refback 08-26-09 06:33 PM
FYI FORD - MustangSteve's Ford Mustang Forum This thread Refback 08-11-09 08:43 AM
FYI FORD - MustangSteve's Ford Mustang Forum: Three ways of adding power steering This thread Refback 08-11-09 06:41 AM
New integral PS box - Vintage Mustang Forums This thread Refback 07-19-09 01:43 PM
New integral PS box - Vintage Mustang Forums This thread Refback 07-17-09 06:43 PM
New integral PS box - Vintage Mustang Forums This thread Refback 07-17-09 01:33 AM
New integral PS box - Vintage Mustang Forums This thread Refback 07-15-09 05:57 PM
New integral PS box - Vintage Mustang Forums This thread Refback 07-15-09 05:55 PM
