07-14-09, 01:47 PM
|  | Premium Sponsor | | Join Date: July 2009
| | | New Mustang Steering Product
Borgeson Universal has now developed and is producing an integral power steering conversion box for the 1965-1970 Ford Mustangs. This is a remanufactured modern power steering gearbox that has undergone extensive modifications to be a direct bolt in for 1965-1970 Mustangs.
The Borgeson conversion box will fit with NO modifications to the shock tower and is a direct bolt in to the factory mounting location. Conversion box is being offered with either a 1" or 1-1/8" sector shaft to fit the original pitman arm.
Column modifications are required as follows. 1965-1967(Early) Mustangs with non-collapsible column will require a replacement column shaft, new column floor mount and complete rag joint. 1967(Late)-1970 Mustangs with factory collapsible column will require factory column to be collapsed about 2" for clearance and a 1/2 rag joint.
IMPORTANT NOTE #1: Borgeson conversion box will NOT fit with factory Z-Bar style clutch linkage.
IMPORTANT NOTE #2: Borgeson power conversion box will operate with stock Ford pump however the power assist will be minimal below 800 RPM. For enhanced response and drivability we offer a Saginaw P/S pump upgrade.
Please add any questions you may have to this thread. These boxes are ready to ship however may not be readily available in distribution for a bit. All components needed for complete conversions are being produced and offered in to distribution by Borgeson.
Thanks, Jeff
Borgeson Universal Company  |
07-14-09, 02:45 PM
|  | Official Member | | Join Date: September 2003 Location: Middle Tn.
07-14-09, 02:58 PM
| | Official Member | | Join Date: July 2005 Location: DFW, Texas
What if we have power steering now with the infamous 'assist cylinder' Does all that come out, if so, what center link do we use, etc? |
07-14-09, 03:26 PM
|  | Official Member | | Join Date: May 2003 Location: Orland Park, Illinois
What's the pricing on these units? |
07-14-09, 04:35 PM
| | Quote:
Originally Posted by Red5oh What if we have power steering now with the infamous 'assist cylinder' Does all that come out, if so, what center link do we use, etc? | The existing control valve and slave cylinder are removed. We have available a drag link adapter to replace the control valve on the 67-70 cars, 65-66 cars will require a 65-66 V8 M/S centerlink. |
07-14-09, 04:36 PM
| | Quote:
Originally Posted by golf4283 What's the pricing on these units? | Suggested retail pricing has been set at $549.00 our delaers however are able to sell it for whatever they like. |
07-14-09, 05:12 PM
|  | Official Member | | Join Date: February 2007
if the cost is low enough you will sell way more of these units! |
07-14-09, 05:26 PM
| | Official Member | | Join Date: May 2007 Location: mission viejo ca.
my headers are about 1/4 away from my steering box, is it dimensionally the same? |
07-15-09, 10:59 AM
| | Quote:
Originally Posted by htwheelz67 my headers are about 1/4 away from my steering box, is it dimensionally the same? | In that location (distance from box to headers) the boxes are dimensionally the same. |
07-15-09, 09:33 PM
cool, I will be in touch, what is the steering ratio of your box? is it designed around the old corrola/cressida boxes? |
07-16-09, 07:22 AM
Another question... how will it 'feel' vs the rack steering? I dont mind my original 67 power steering, but the rack's are much more tight feeling, etc. I hope I have explained my question well... Thanks. |
07-16-09, 07:46 AM
| | Quote:
Originally Posted by htwheelz67 cool, I will be in touch, what is the steering ratio of your box? is it designed around the old corrola/cressida boxes? | No, the core we are using is coming from 1995 and newer production vehicles. The older technology in the 70's - 80's Toyota Corrola steering boxes does not provide a significant improvment over a properly serviced and adjusted stock set-up. We use a more modern box for all of our conversions to provide true modern power steering feel and feedback. |
07-16-09, 07:48 AM
| | Official Member | | Join Date: April 2009
| | Quote:
Originally Posted by Borgeson IMPORTANT NOTE #1: Borgeson conversion box will NOT fit with factory Z-Bar style clutch linkage. | Why not? The height of the top appears identical, and of course the steering shaft shaft lines up with the existing steering column, which the equalizer clears. |
07-16-09, 07:51 AM
| | Quote:
Originally Posted by Red5oh Another question... how will it 'feel' vs the rack steering? I dont mind my original 67 power steering, but the rack's are much more tight feeling, etc. I hope I have explained my question well... Thanks. | Our box will provide a great feel, comparing it to a rack is a little difficult as a rack and pinion eliminates pivot points from the steering system. However most rack and pinion conversions will reduce your turning radius and the rack ends up being mounted very low on the vehicle. If you were to replace all front end wear items such as rod ends and idler arms while installing our conversion box you will be quite please with the feel of the steering and maintain your full turning radius. |
07-16-09, 08:05 AM
| | Quote:
Originally Posted by 2+2GT Why not? The height of the top appears identical, and of course the steering shaft shaft lines up with the existing steering column, which the equalizer clears. | It has a nasty habit of removing the P/S hoses from the top of the box. The box itself clears but we cannot source any P/S fittings with a low enough profile to clear the hoses. |
07-16-09, 12:00 PM
| | | Pump upgrade question
You mention that pump assist will be minimal below 800 rpm with the stock pump. Are there high rpm effects as well?
One of my biggest problems with the stock system is that the steering feels too easy at highway speed, which I have read is a function of the proportional flow rate. If this effect will remain with the new box, does the Saginaw replacement pump have a more consistent rate of flow?
Also, is the box know to be compatible with any aftermarket columns?
Thanks |
07-16-09, 12:07 PM
| | Quote:
Originally Posted by other_shoe You mention that pump assist will be minimal below 800 rpm with the stock pump. Are there high rpm effects as well?
Thanks | No adverse effects at highway speed. The Ford pump does not generate sufficient pressure / flow at low RPM's to properly operate the box. Stock slave cylinder set-ups are very vague with no feedback, our box will have a good effort required at highway speed because of the modern variable assist valve.
We are working with IDIDIT to ensure that our box can be compatible with their replacement column.
Thanks |
07-16-09, 03:58 PM
| | Member | | Join Date: June 2009
Thanks for keeping us updated. Is there any more info/pics/specs? Checked your website but didn't see anything.
Looks like a lot of us are concerned about the same things: Price, Steering Feel and Fit. Is the price for a 65-66 $549 with everything you would need to install it? Also, just to confirm, this is actually a power box, correct? No hydraulic arm, etc? I think the arm is what kills the steering feel, so this one should feel pretty decent.
Also, are there options for ratio? 12:1, 16:1, etc?
Thanks again |
07-16-09, 04:11 PM
| | Quote:
Originally Posted by racerboyrt Thanks for keeping us updated. Is there any more info/pics/specs? Checked your website but didn't see anything.
Thanks again | It is indeed an integral power steering box that eliminates the factory style control valve and slave cylinder. Only available in one ratio 16:1 or 4 turns lock-to-lock. The suggested retail of $549 is for the box only; total cost will depend on items required for individual conversion. I do have some more pictures of fit / clearance on a 1968 Small block with Tri-Y headers. For photo's and other details that I have in a word doc. send me a request via e-mail to: jeff @ borgeson . com (remove spaces) and I will respond as soon as practical.
Thanks, Jeff |
07-16-09, 06:22 PM
|  | Member | | Join Date: August 2005 Location: scotand u.k
do you have pics of this actual unit fitted in a mustang? |
07-16-09, 06:31 PM
| | Official Member | | Join Date: February 2004 Location: SF Bay Area
| | Quote:
Originally Posted by Borgeson I do have some more pictures of fit / clearance on a 1968 Small block with Tri-Y headers. For photo's and other details that I have in a word doc. send me a request via e-mail to: jeff @ borgeson . com (remove spaces) and I will respond as soon as practical.
Thanks, Jeff | ^^ |
07-17-09, 03:38 PM
| | | Power Box Application Details 1965-1966 Mustang (1” Diameter Sector Shaft) Factory P/S Cars Require:
Power Steering Box
Power Steering Hose Kit
Steering Column Shaft / Floor Mount
Complete Rag Joint
65-66 V-8 M/S Center link Manual Steering Cars Require:
Power Steering Box
Complete Rag Joint
P/S Pump, Bracket and Pulley Kit 1967 Mustang (Must verify sector shaft diameter 1” or 1-1/8”) Note: Cars with ¾” Diameter non-collapsible column shaft will require part #990040 Steering Column shaft/ floor mount and #052534 Complete Rag Joint not ½ rag joint. Factory P/S Cars Require:
Power Steering Box
½ Rag Joint
Drag Link Adapter Manual Steering Cars Require:
Power Steering Box
½ Rag Joint
P/S Pump, Bracket and Pulley Kit 1968-1970 Mustang (1-1/8” Diameter Sector Shaft) Factory P/S Cars Require:
Power Steering Box
½ Rag Joint
Power Steering Box
½ Rag Joint
P/S Pump, Bracket and Pulley Kit |
07-17-09, 03:39 PM
| | | Power Conversion Box Part #'s Mustang Conversion Part #’s
800110 – Power Steering Box, 65-67, 1” Diameter Sector Shaft
800111 – Power Steering Box, 67-70, 1-1/8” Diameter Sector Shaft
990040 – Steering Column Shaft, with Floor Mount1965-1967 (Early)
925107 – P/S Hose Kit, Ford Conversion Box to Ford Pump
925108 – P/S Hose Kit, Ford Conversion Box to Saginaw Pump Upgrade
052534 – Rag Joint, Conversion Box to Borgeson Column Shaft
990016 – ½ Rag Joint, Conversion Box to Rag Joint Flange on Stock Column
990003 – 1967-1970 Mustang Drag Link Adapter, Replaces Control Valve
990050 – 1965-1966 V-8 Manual Steering Drag Link
800330 – 1965-1970 SBF Mustang Saginaw P/S Pump Upgrade Inc: Pump, Pulley, Bracket |
07-17-09, 06:34 PM
|  | SuperMod Canadian Colossus | | Join Date: August 2002 Location: Ontario, Canada
Welcome. Glad we got everything straitened out.  |
07-18-09, 08:10 AM
| | Founding Member | | Join Date: August 2002 Location: lubbock, texas
| | Quote:
Originally Posted by Borgeson 1965-1966 Mustang (1” Diameter Sector Shaft) Factory P/S Cars Require:
Power Steering Box
Complete Rag Joint
Power Steering Box
Complete Rag Joint
Power Steering Box
½ Rag Joint
Power Steering Box
½ Rag Joint
Power Steering Box
½ Rag Joint
Power Steering Box
½ Rag Joint
will this box work on other ford vehicles that use the same steering gear? for example; ranchero, torino, falcon, fairlane, etc ? | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | | | |
