Mustang Forums at StangNet
01 COBRA CLUTCH NOISE NEED HELP!
This is a discussion on 01 COBRA CLUTCH NOISE NEED HELP! within the SVT Tech forums, part of the SVT category; I HAVE A 2001 COBRA HEAR A SQUEAKING NOISE WHEN IDELING AND A LIGHT PRESS OF THE CLUTCH IT GOES ...
Go Back   Mustang Forums at StangNet > Mustang Forums > SVT > SVT Tech
Over 151,000 Members!!
Reply
  #1 (permalink)
Old 07-17-09, 12:26 PM
I HAVE A 2001 COBRA HEAR A SQUEAKING NOISE WHEN IDELING AND A LIGHT PRESS OF THE CLUTCH IT GOES AWAY BUT WHEN I LET OFF I STILL HERE IT.IS THIS A PROBLEM THIS IS MY FIRST STANG AND HAS A NEW CLUTCH
  #2 (permalink)
Old 07-17-09, 03:47 PM
Shamus O'toole's Avatar
Official Member
Was the throw out bearing replaced when the clutch was replaced??
  #3 (permalink)
Old 07-17-09, 04:01 PM
YES IT WAS REPLACED. DO YOU THINK IT MIGHT NEED TO BE ADJUSTED
  #4 (permalink)
Old 07-17-09, 08:33 PM
Official Member
You may have put it in incorrectly, and it caused it to fail prematurely.
  #5 (permalink)
Old 07-20-09, 08:47 AM
grrrrrr. how much will that cost i just bought the car the guy before me said he had it replaced and gave me a receipt on it .
  #6 (permalink)
Old 07-24-09, 07:49 AM
Kilgore Trout's Avatar
Fried or Broiled ?
A lot of times TOB will fail after a year or so. Mine did... Its a Mustang thing.
It helps to have the clutch adjusted properly.
  #7 (permalink)
Old 07-28-09, 09:11 PM
I had just put a specc in my 99 and at 2000 miles it started doing the same thing we pulled it apart and the throw out bearing was faulty
  #8 (permalink)
Old 08-06-09, 08:37 AM
how much will a mechanic shop charge to change that?around about i know the bearing is $30 bucks
  #9 (permalink)
Old 08-06-09, 01:10 PM
Fried or Broiled ?
When I had mine replaced the removal and reinstall of the trans was $270 in labor.
  #10 (permalink)
Old 08-10-09, 09:36 AM
i talked to the mechanic who did the work and he seems to think its the shaft bearing could that be?im trying to sell the car and i want to be fair with the buyer.the car drive and shifts fine just a little noise when i start it up. what is a reasonable sell price?
  #11 (permalink)
Old 08-10-09, 10:23 AM
Fried or Broiled ?
Reasonable price for an 01 Cobra with clutch issues? That is a tough one it is hard enough to price Cobras without the clutch issue in play. You need to provide a lot more info for a good appraisal or you can check N.A.D.A. Home Page and New Cars, Used Cars, Blue Book Prices & Car Values - Kelley Blue Book for rough guidelines.
  #12 (permalink)
Old 08-14-09, 10:30 AM
tfritz's Avatar
My '01 cobra's clutch is just now going out and I'm getting the sound as well....I still have the original clutch/cable/throwout and my car has 151,000miles
  #13 (permalink)
Old 08-18-09, 03:02 PM
shaft bearing? i drove the car 125 miles no problems just a little noise like a belt
  #14 (permalink)
Old 08-20-09, 10:24 AM
tfritz let me know what u come up with and guys thanks for the input
  #15 (permalink)
Old 10-24-09, 09:53 PM
i'd say pilot bearing. your throwout bearing should be in contact rotating with the pressure plate fingers at all times and the sound probably would not go away like that. Your pilot bearing which supports the end of the input shaft would stop rotating when the clutch is pushed in, disconnecting the power transfer from the flyheel to the clutch, and allowing the input shaft to slow to a stop. If it's not rotating the squeal goes away.
Reply
Thread Tools
Display Modes
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
