Mustang Forums at StangNet
Problems with 2.3 staying running
This is a discussion on Problems with 2.3 staying running within the 2.3L (N/A & Turbo) Tech forums, part of the 2.3L Mustang category; I am new to this forum since this is my first 2.3. Problem is that the car starts and idles. ...
Go Back   Mustang Forums at StangNet > Mustang Forums > 2.3L Mustang > 2.3L (N/A & Turbo) Tech
Over 151,000 Members!!
Reply
  #1 (permalink)
Old 07-28-09, 04:32 PM
I am new to this forum since this is my first 2.3. Problem is that the car starts and idles. If you put it in gear it dies, also if you let it idle long enough it will start shaking, sputter, cough and die. It also spit out like black carbon out the tail pipe. I have replaced plugs, wires, dist cap, and pressure regulator. Another question is do you need a special wrench to tighten dist or just try to fit my hand down in there? Any help would be great. I bought the car like this and trying to fix it with out pouring money into randomly replacing parts. Thanks
  #2 (permalink)
Old 07-29-09, 08:57 PM
rd rd is offline
I would pull the codes before doing anything. The country boy jumper wire method and some careful counting will work in a pinch.
Based on the above, I replaced the MAP or baro sensor on my 89 2.3 a couple years ago and cured a similar problem.
  #3 (permalink)
Old 07-30-09, 09:21 AM
Red_LX's Avatar
Doubt I could be of much help, unless you need porn pics!!
Location: Morgantown, WV...where couches meet their doom
What do you mean by "pressure regulator?"
And, the distributor bolt is hard to reach. You need a socket, universal joint, and then a long extension to reach it. Can't remember the size off the top of my head.
  #4 (permalink)
Old 07-30-09, 11:23 AM
90mustangGT's Avatar
I felt sorry for girls because I thought they didn't have anything....now all I want is what I thought they didn't have.
Slow IAC would be what I would look at first.
  #5 (permalink)
Old 07-30-09, 03:54 PM
I changed the fuel pressure regulator. It was bad and it at least starts everytime now just not for long. Also what and where is the IAC? I should have a code reader this weekend so I can pull some codes. Thanks for the help.
  #6 (permalink)
Old 07-31-09, 09:04 AM
Red_LX's Avatar
IAC is mounted to the back of the throttle body. Looks like a cylinder about 4" long or so and has some wires plugged into it.
Does it rev up ok?
  #7 (permalink)
Old 07-31-09, 09:52 PM
When I start the car it idles fine and reves up, but after a minute or two it starting coughing and shaking then dies.
  #8 (permalink)
Old 08-01-09, 10:13 AM
Dr_EluSivE's Avatar
I would check the timing..
Dr.
  #9 (permalink)
Old 08-01-09, 11:13 PM
The timing is set correctly and I also changed the fuel filter. It still starts and runs for about 30 seconds then it acts like it just shuts off, like you turned off the key.
  #10 (permalink)
Old 08-02-09, 09:46 PM
blakmustang93's Avatar
It might be the catylitic converter. I had a similar problem on mines until it completely plugged up and car wouldnt run at all check it out see if thats your issue
  #11 (permalink)
Old 08-03-09, 09:27 PM
mine only idles at 1250-1500 rpm any lower and it dies or if i put it in gear it dies why?
  #12 (permalink)
Old 08-05-09, 12:04 PM
How do I check to see if the cat convertor is plugged up?
  #13 (permalink)
Old 08-06-09, 03:56 AM
is that the problem?
  #14 (permalink)
Old 08-08-09, 02:28 AM
I thought mines was the cat. turns out its a couple hoses that are airlines that wore out along with some kind of piece that goes along the transmission... sorry i cant be much help cost me 75 at my mechanic to fix it car runs like a champ again.
Reply
Thread Tools
Display Modes
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
