Mustang Forums at StangNet
looking for bellhouse/flywheel mustang II
This is a discussion on looking for bellhouse/flywheel mustang II within the MII Discussion forums, part of the Mustang II category; hello out there does anyone know where i can locate a 75-78 mustang 2 bellhousing flywheel and starter assembly? i ...
Go Back   Mustang Forums at StangNet > Mustang Forums > Mustang II > MII Discussion
Over 151,000 Members!!
Reply
  #1 (permalink)
Old 07-30-09, 02:58 PM
hello out there does anyone know where i can locate a 75-78 mustang 2 bellhousing flywheel and starter assembly? i am building a 92 ranger with a 5.0 c4 trans combo and was told that this bellhousing will help with clearence issues..also does anyone know if this bellhousing and flywheel will be compatable with a 302 c4 auto out of a 94 mustang gt?
  #2 (permalink)
Old 07-30-09, 08:22 PM
welder4956's Avatar
Official Member
Quote:
I don't think the '94 came with a C4. It was an AODE I think. The MII bell from the C4 should bolt to any other C4. I think the 141-tooth flexplate is available from Art Carr with a 50 oz. imbalance for the late model 5.0. Starter should be available from NAPA.
  #3 (permalink)
Old 08-07-09, 12:21 AM
zwhitr's Avatar
You want to use the high torque mini starters not the big a$$ II starter
starts better and meshs up better with flywheel the balance weight is dependent on the engine the 302 vs 5.0 used different balance scheme
Good luck finding a II bell housing only us II users are willing to admit using them. They uses a much smaller diameter flywheel which helps the Torque converter stall.
  #4 (permalink)
Old 08-09-09, 10:56 AM
Hello
I have a bellhousing a flex plate and a 4500 stall con. if your interested. I also have left and right side motor mounts for v8 in the mustang II
  #5 (permalink)
Old 08-16-09, 10:08 AM
Sent you a pm.
  #6 (permalink)
Old 08-18-09, 06:24 AM
Still interested in these. Let me know if you still have them and some prices.
Reply
Thread Tools
Rate This Thread:
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
