Mustang Forums at StangNet
what is dashpot?
This is a discussion on what is dashpot? within the 94-95 5.0 Tuning forums, part of the 94-95 Tech category; Is there anywhere i can read up on dashpot settings? I do not understand where to start. I do believe ...
Go Back   Mustang Forums at StangNet > Mustang Forums > 5.0 Mustang > 94-95 Tech > 94-95 5.0 Tuning
Over 151,000 Members!!
Reply
  #1 (permalink)
Old 08-04-09, 02:42 PM
tealstang67's Avatar
what is dashpot?
Is there anywhere i can read up on dashpot settings? I do not understand where to start. I do believe this is where my idle issues are coming from. My idle is all jacked up and i think the dashpot drops off to quickly there for causes it to stall and die.
  #2 (permalink)
Old 08-04-09, 03:37 PM
pirotec354's Avatar
Official Member
Dashpot is the decay rate of the rpms coming down and finding idle from what i understand. Its usually shown as bypass airflow from the iac at closed throttle vs engine speed. You want to contour this so it will drop quickly at higher rpm's once the throttle is closed and slows as it approaches idle. If it is to fast is will drop right past idle and stall/die. It may just take some trial and error to get it perfect.
I see you also have a supercharger, this will also cause problems since there is excess pressure in front of the throttle plate. You want to keep the dashpot values low since your iac is fed from a pressurize source.
You can also go over too eectuning.org and read up on it there. Im sure theres some good info over there. i think Ive seen you over there? Not sure if im remembering correctley though. Hope this helps.
Also you want to take into account for larger throttle bodies and such.
-Justin
  #3 (permalink)
Old 08-04-09, 03:57 PM
That helps a little, As far as pressure in front of the TB a KB is a draw through setup there for it only has vacuum in front of the TB. The dashpot settings and TB air flow is where i need to start i think.
  #4 (permalink)
Old 08-05-09, 07:53 PM
pirotec354's Avatar
Official Member
Its still going to affect the iac b/c more air is being fed through it.
Reply
Thread Tools
Display Modes
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
