08-06-09, 08:42 PM
|  | Member | | Join Date: January 2008 Location: Houston, TX
| | | 2.3L Perfomance?
I just sold my 302 fox and got a 2.3L 91 hatch. What are some ways to get some power out of these motors? |
08-06-09, 10:40 PM
| | Member | | Join Date: August 2009
to be honest...there are not too many cheap ways it can be done...
because of its size....n/a is not a option
these motors are not known for being anything great..
but if you have to make it fast....turbo it |
08-07-09, 09:02 AM
|  | Founding Member | | Join Date: April 2002 Location: Central Illinois
You can get ~230hp with a turbo swap without much effort, More requires Headwork, bigger turbos, fuel, and other more expensive parts.
Dr. |
08-15-09, 09:52 PM
| | Member | | Join Date: November 2008
turbos are unnessacery but nice
1. factory ford computer is JUNK timing curve is way off and has built in rev limeter 5500-5800
2 intakes dont flow for nothing.
3. compression is way to low
4. cam is small
I have an 88 lx that im pullin the efi off of, swaping in a carb sending unit and putting a carb on it. it all ready has a racer walsh header,w/ 2 1/4 back flow master,r/w adjustable cam gear and factory non roller tubo cam.
head will be milled to aprox 9.6-1 compresision
this is the 4th time i built this combo this is the only one that disapointed me
the last 2 made over 160 flywheel horse power(there in my two brothers sand rails)
they could of made more with morre than the factory 8.7 -1 ratio, but they go to mexico and get some crummy gas
acording to eslinger this combo out to make 175 180 hp @ 7200 rpm
its a small 4 cyl SPIN IT |
08-17-09, 09:01 AM
|  | Doubt I could be of much help, unless you need porn pics!! | | Join Date: August 1998 Location: Morgantown, WV...where couches meet their doom
Dude there is no ****ing way you made "over 160 hp" on an n/a 2.3 with a carb, header, adjustable cam gear, turbo cam and a little milling of the head. Or wait, did you say they made that much on the stock compression ratio?
08-20-09, 10:34 PM
|  | Founding Member | | Join Date: September 2000 Location: Antelope Valley, SoCal
Yeah, I don't see an NA 88hp 2.3 gaining 72hp+ while keeping the stock longblock.....
As far as suggestions for getting more power out of a 2.3NA, that's why we have a search function here; so you can find all the other times that same question was asked and answered.
09-09-09, 07:01 AM
| | Member | | Join Date: August 2009 Location: Italy TX
what all can i buy for my 87 to boost power without having to buy a turbo or supercharger i already have a custom intake any sudgestions? |
09-09-09, 11:31 AM
|  | Lord of The somethin' somethin' somethin', hell, I can't be doing this all night, ya know. | | Join Date: October 1999 Location: Lord of uh, hmm what was it again?
Back in the day didn't Crovax have a bunch of stuff on his n/a and it still hardly made any power?
For the cost involved finding a wrecked TC is much cheaper/easier.... |
09-09-09, 01:28 PM
| | Quote:
Originally Posted by Rcdriver45 what all can i buy for my 87 to boost power without having to buy a turbo or supercharger i already have a custom intake any sudgestions? | I would suggest using the search feature. This same exact question comes up at least once a week, so you should find lots of answers. Quote:
Originally Posted by SVO1 Back in the day didn't Crovax have a bunch of stuff on his n/a and it still hardly made any power? | His and all the other built pump gas 2.3NAs. |
09-09-09, 09:27 PM
would the tornado fuel saver do anything to help? |
09-09-09, 11:40 PM
You're joking...........right? Please tell me you are. |
09-10-09, 10:58 AM
| | Quote:
Originally Posted by Rcdriver45 would the tornado fuel saver do anything to help? | It won't actually.
We tested one and the only gain we found is if we left it out, then we dropped .00000000000001 off our drag times. why? Less weight in our wallet.
Putting the tornado in added back the weight we lost, and caused us to gain back that .00000000000001 |
09-10-09, 12:13 PM
I see you snuck back in here, Jay! |
09-10-09, 06:55 PM
well dead gum! Ok im willin to try anything! |
09-10-09, 09:27 PM
| | Quote:
Originally Posted by Rcdriver45 well dead gum! Ok im willin to try anything! | Put a 100 horse wet kit on it.
Serious. It will be more fun and if setup right it will last a while.
And yeah Garrett, I snuck back in  Been a long time, but now that I'm unemployed I have all kinds of time!!!! |
09-10-09, 10:44 PM
how much would a kit cost? |
09-12-09, 12:25 PM
Check with any performance shop of your choice. Summit Racing, Jegs, and $500 come to mind. |
09-14-09, 08:23 AM
And to add, that's $500 with an empty tank. Make sure there's a nitrous filling station somewhere near you. |
09-14-09, 01:30 PM
and make sure you read up and understand the PROPER way to setup/tune for a Nitrous system.
If you don't know about timing adjustments, spark plug heat ranges, how to read plugs etc, DO NOT put a kit on your car.
And since I see it coming, Yes you can use a kit for a 5.0 or a generic kit, but you will have to do some modifying to make it work on your car. | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is On | | | | | |
