Mustang Forums at StangNet
C&L mass air tube from 19lb to 24lb questions
This is a discussion on C&L mass air tube from 19lb to 24lb questions within the Fox 5.0 Tuning forums, part of the 5.0 Tech category; I have a 89 5.0 with gt-40 p heads, e-cam, 76mm C&L system I just installed 24lb injectors, and air ...
Go Back   Mustang Forums at StangNet > Mustang Forums > 5.0 Mustang > 5.0 Tech > Fox 5.0 Tuning
Over 151,000 Members!!
Reply
  #1 (permalink)
Old 08-08-09, 11:32 PM
Official Member
Question C&L mass air tube from 19lb to 24lb questions
I have a 89 5.0 with gt-40 p heads, e-cam, 76mm C&L system I just installed 24lb injectors, and air tube now it doesnt run right, at full throttle it is sluggish, and at a certain point on throttle it has a miss in it . Does the mass air have to have anything electrical also like computer. I have 110lph fuel pump and March ram air and 70 mm throttle body stock intake P.S. How much fuel pressure should I set it at, I don't know where it is now, but will check it tomorrow.
  #2 (permalink)
Old 08-09-09, 03:55 AM
vristang's Avatar
Official Member
You do need to change the sample tube in the MAF when you change injector size.
The C&L site has the details on their calibration page.
http://www.cnlperformance.com/calibration.html
baseline fuel pressure should be in the 38-41psi range... measured with the vac line disconnected.
  #3 (permalink)
Old 08-09-09, 08:37 AM
Official Member
After looking at that chart, I see that the 24lb tube is blue, but the one I got off ebay has no color, the only thing marked is a #2 on it. It is however bigger than the one I took off. Does anyone know which way the air tube goes in the housing, because whne I took the old one off I (in a hurry) didnt pay attention which way it was, I tokk the housing off and loked at it anyway I put the beveled in toward the filter would make a difference if I turned it?
  #4 (permalink)
Old 08-09-09, 01:29 PM
Official Member
I put the screen in front of the maf and it helped it alot. The fuel pressure was 42 when first checked reduced it to 38lb, is the pressure suppose drop when on the throttle?
Reply
Thread Tools
Display Modes
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
