Mustang Forums at StangNet
I need help
This is a discussion on I need help within the 2.3L (N/A & Turbo) Tech forums, part of the 2.3L Mustang category; I bought a 1992 mustang lx 2.3 and when you turn the key to run the fuel pump won't prime ...
Go Back   Mustang Forums at StangNet > Mustang Forums > 2.3L Mustang > 2.3L (N/A & Turbo) Tech
Over 151,000 Members!!
Reply
  #1 (permalink)
Old 08-11-09, 08:49 PM
Unhappy I need help
I bought a 1992 mustang lx 2.3 and when you turn the key to run the fuel pump won't prime but if you hold it between run and start the pump primes the car will start and run like a top if you hold the key between run and start I picked up a RCM module from a junk yard but same thing replace fuel pump relay same, starter relay same, ignition cylinder, ignition module on the column same, the guy did go from electric windows to manual so he cut those wires but thats all he cut, whats got me is that when you let it fall to run it kills spark and all cause i've already jumped the pump to run constant and it starts but if you let the key roll to run it dies.
  #2 (permalink)
Old 08-13-09, 05:47 PM
try the ignition switch sounds like a similar problem i had and my switch was bad only half of it was working lol
  #3 (permalink)
Old 08-15-09, 11:41 PM
i agree
  #4 (permalink)
Old 08-15-09, 11:46 PM
rd rd is offline
Check the ignition switch. On a Fox it is adjustable, as there are slots on the switch for the hold down screws.
If adjusting does not fix it, replace the switch.
You may want to trace the wiring from the eec relay and eec box to make sure it is getting powered in the start postion of the key before changing anything.
Reply
Tags
92 lx, running, won't run
Thread Tools
Display Modes
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
