Mustang Forums at StangNet
WHAT DO I NEED ????? HELP
This is a discussion on WHAT DO I NEED ????? HELP within the SVT Tech forums, part of the SVT category; Ok this is the deal > Fri night I'm going to Iland drag way > I have one vette and ...
Go Back   Mustang Forums at StangNet > Mustang Forums > SVT > SVT Tech
Over 151,000 Members!!
Reply
  #1 (permalink)
Old 08-11-09, 08:51 PM
jeremy canter's Avatar
Official Member
Garage
Smile WHAT DO I NEED ????? HELP
Ok this is the deal > Fri night I'm going to Iland drag way > I have one vette and two camaros I'm going to race > one camaro is stock lt1 > easy win for me > the vette is a stock 94 with M/T drag radials > I'm pretty sure I can beat it > the second camaro is what I want to kill bad >Its got a worked motor and is supost to run mid low 13's> the kid has been running around town telling every one he beat me / but we have never raced> but when I said something to him he back pedled > fast > It sound childish but hey its going to happen !!! >
My car is a 98 Cobra the bst I run stock was a 14.1 at 100mph it now has a MAC cat back and cat-less x-pipe > I have a JLT filter kit for the mass air sensor i'm going to put on and a set of under drive pullys > Today I just put a new set of Nitto 275/40/17 Drag radials on the back .
I also have a WET nitrous kit that I plan on spraying a 90 hp shot threw >I don't have time to order or buy anything else for the carbefore Fri night ..... will all this get me to the high 12's or low 13's?
  #2 (permalink)
Old 08-11-09, 10:12 PM
StangGT1995's Avatar
have car, will race....wait, it doesn't run
With 100 MPH trap speeds, you're already knocking on 12's. How was your 60' time? What year is the Camaro with that's only running 13's with a worked engine? If it's an LS1 Camaro, it's 12 second capable off the showroom floor, so you might have a bit more trouble there. It sounds like you just need practice. Good launches and consistent shifts, while driving it like you stole it.
  #3 (permalink)
Old 08-12-09, 01:12 AM
Official Member
Garage
both camaro's have lt1 motors> but the one i want to kill at the track is suppost to have a Liendifeltter vette motor in it > but it only ran a 13.5 at the track/ my 60. foot times are like a 2.2 > I did have alot of trouble with traction at the track and chirped the tires all the way to fourth gear. thats why I bought the drag radials> so I can launch harder.
whats the best clutch to put in my 98 cobra ?
  #4 (permalink)
Old 08-12-09, 05:41 PM
32ValveRom's Avatar
Official Member
Sounds like you won't need much if you're saying they're both LT1s and a 13.5 Vette. If I were you I'd get a tune with that wet-kit along with 4.10s. Cai and LTs wouldn't hurt either.
  #5 (permalink)
Old 08-12-09, 09:39 PM
Official Member
Garage
Smile
Quote:
I want LONG TUBES but there $400 plus a x-pipe > so thats out for a while till I get some cash> I put a JLT filter pack on the car today > no cash for a cold air yet > and I only plan on spraying tops 90 hp with the nitrous > so I don't think I need a tune just yet > but I don't know crap about N2O so ????
  #6 (permalink)
Old 08-15-09, 08:04 PM
Official Member
Garage
chicken sit vettes didn't show and the green camaro backed out at the last min > the silver camaro did show and ran good after a few runs > but only put out 14.4 at 95 > not anuff to get around me > > the drag radials didn't help me any at all I only managed to put down a 14.2 > at 99.16 th track seamed slick to me but some dum kid blew his VW up at the burn out box and sprayed oil all over the starting tree area and the track was crap for the rest of the night >
I WANT TO KNOW WHAT I NEED TO DO TO RUN 12's > WHAT DO I NEED TO DO TO MY CAR TO RUN 12's!!!!!!!
  #7 (permalink)
Old 08-15-09, 08:27 PM
Congratulations on your win.
Quote:
Drive it. There's not much else that needs to be done, really. Practice, practice, practice, and when you think you have your launches down, practice them some more. Some gears (4.10's to 4.30's), sticky tires, and just literally driving the wheels off the car is what will get you there. With your nitrous, you should be there now.
  #8 (permalink)
Old 08-16-09, 07:23 PM
Official Member
Garage
I just got Nitto drag radials (275-40-17) and the was NO HELP lowering my 60 foot times > last time I ran on street tire's and still run 2.2 in the 60ft AND YES I HEATED THE HE!! OUT OF THEM > my 1/4 mile times are stuck at 14.1-14.2> at 99 mph > and thats shifting at 6200 -6500 RPM"S and the car is braking the tire's lose even the 3rd-to-4th SHIFT !!!!! > I have not sprayed the car (yet) I need the fuel rail fitting to hook the fuel up to my nitrous kit. > I plan to spray a 90 shot when I get it .
  #9 (permalink)
Old 08-16-09, 08:01 PM
What tire pressures are you running?
  #10 (permalink)
Old 08-16-09, 09:56 PM
Official Member
Garage
16# in the passanger rear > 18# in the driver> buy the end of the night < I started out with both at 30#'s running about 32# in the front
  #11 (permalink)
Old 08-17-09, 11:41 PM
John00Stang's Avatar
Yea what he said-Practice. I would hold off on the nitrous until you get your traction problems under control. If you just keep adding stuff to get more power, things could end badly. Oh and what nitrous kit? make sure you use a window switch. As far as beating the other cars, don't make that your goal. Next time your at the track, ask the staging guy to let you make a couple solo runs to maybe calm the nerves brought on by racing someone else. Other than that, your next mods should be 4.10's and upper and lower control arms. power is nothing if you can't hook up! Good luck.
  #12 (permalink)
Old 08-18-09, 08:54 PM
Official Member
Garage
I NEED GEARS > THATS WHAT I HUNTING for > I found a set of 3:73's > cheap > so thats next> I bought a set of long tube headers tonight > hopefully I can cut my x-pipe to fit >
  #13 (permalink)
Old 08-19-09, 01:21 PM
Quote:
power is nothing if you can't hook up! thats correct
  #14 (permalink)
Old 08-28-09, 09:11 PM
Official Member
Garage
I got my nitrous hooked up ( 100 shot ) with a nice purge valve / long tube headers are on there way > hope to find a x-pipe this week > and after a little over time at work I'll order my JLT cold air intake >
  #15 (permalink)
Old 08-31-09, 06:35 AM
dustang50's Avatar
Official Member
+1. I had similar problems until I touched up the suspension on my GT. Also - don't fear the gear!
Reply
Thread Tools
Display Modes
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
