Mustang Forums at StangNet
Engine Help Needed
This is a discussion on Engine Help Needed within the 2.3L (N/A & Turbo) Tech forums, part of the 2.3L Mustang category; I have an '89 lx 2.3L which ran fine up until an squirrel got up in the engine compartment. I ...
Go Back   Mustang Forums at StangNet > Mustang Forums > 2.3L Mustang > 2.3L (N/A & Turbo) Tech
Over 151,000 Members!!
Reply
  #1 (permalink)
Old 08-13-09, 12:14 PM
Exclamation Engine Help Needed
I have an '89 lx 2.3L which ran fine up until an squirrel got up in the engine compartment. I tried to start the car and had no luck. When I popped the hood, I found that the squirrrel chewed a few wires. The wires went to the throttle position sensor and the air bypass valve. I spliced the wires back together. The engine will crank but will not fire. I have spark and fuel pressure in the fuel rail. I pulled the plugs and put fuel in the cylinders and it fired right up and ran until the fuel was gone. I can spray starting fluid in the throttle body and it will fire also. Any ideas on why I can't get fuel through the injectors to the cylinders? Help!
  #2 (permalink)
Old 08-15-09, 11:11 PM
1.put a meter on injector
2.check for pulse while cranking
3.if pulse you have clogged fuel rail/bad regulator
4.if im not mistaken ford grounds the injector to fire so check for power to injectors with key on
5.i do beleave some one made up a no start chart for these might want to check archives
have fun
Reply
Thread Tools
Display Modes
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
