Hi Mstngd21,
When you turn the key, do the accessory lights dim? If not, power is not getting to the starter, or the starter relay. If the lights do dim, double check the wiring around the relay, it could possibly be a wire going to the starter relay or the starter is hooked up incorrectly or a wire is loose. Just as a safety precaution, whenever you work on the wiring, disconnect the battery.
