Mustang Forums at StangNet
How to test for a vacuum leak?
This is a discussion on How to test for a vacuum leak? within the 2.3L (N/A & Turbo) Tech forums, part of the 2.3L Mustang category; am trying to check my car for a vac leak. 89 mustang 2.3L. I dont hear anything obvious. What kind ...
Go Back   Mustang Forums at StangNet > Mustang Forums > 2.3L Mustang > 2.3L (N/A & Turbo) Tech
Over 151,000 Members!!
Reply
  #1 (permalink)
Old 08-15-09, 02:22 PM
am trying to check my car for a vac leak. 89 mustang 2.3L. I dont hear anything obvious. What kind of equipment do I need and where do I get it. Also how do I run the test. Thanks
  #2 (permalink)
Old 08-15-09, 11:17 PM
the easiest way to check.......well may be the safest is using soapy water
spray in areas of concern idle should stabilize as mixture temporaly closes off vacuum leak
i use carb cleaner BUT ITS DANGEROUS i have caught more than one car on fire
  #3 (permalink)
Old 08-16-09, 03:48 PM
Official Member
The way I check for boost leaks can be used for vacuum. Hook item in picture to throttle body and pressurize to LESS than 10psi and can hear or feel the leak. Minus the black metal pipe.
http://i177.photobucket.com/albums/w...5/100_5699.jpg
  #4 (permalink)
Old 08-17-09, 09:11 AM
Red_LX's Avatar
Doubt I could be of much help, unless you need porn pics!!
Location: Morgantown, WV...where couches meet their doom
Vacuum leaks are very difficult to find on newer cars. About the only thing you can do is go over everything very carefully and see if anything is obviously disconnected or cut.
Reply
Thread Tools
Display Modes
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
