Quote:
Originally Posted by NotA5oh So if I want to have a wideband for each side then I'll have to cut in a spot for the stock style o2's so it doesn't mess up the ecu? |
If you are using the Livewire to disable the rear O2s then that is where you install the wideband O2s. The computer only uses the front O2s for adjustments anyway. The rear O2s are just there to make sure the front ones are working.
