Mustang Forums at StangNet
Where can I get coolant bypass O-rings
This is a discussion on Where can I get coolant bypass O-rings within the SVT Tech forums, part of the SVT category; I removed the coolant bypass pipe on my 01 Cobra, the one with the bleeder in it and I'm trying ...
Go Back   Mustang Forums at StangNet > Mustang Forums > SVT > SVT Tech
Over 151,000 Members!!
Reply
  #1 (permalink)
Old 08-16-09, 07:04 PM
4.6andSlicks's Avatar
Official Member
I removed the coolant bypass pipe on my 01 Cobra, the one with the bleeder in it and I'm trying to replace the o-ring on either end of it before reinstalling but I can't find them anywhere.
I haven't checked the dealer but I can't believe a parts store wouldn't have something like this. I thought maybe I'm calling the by the wrong name or something.
Any help out there?
  #2 (permalink)
Old 08-16-09, 07:07 PM
jeremy canter's Avatar
Official Member
Garage
NAPA ?
  #3 (permalink)
Old 08-16-09, 07:41 PM
Official Member
Quote:
Originally Posted by jeremy canter View Post
NAPA ?
That was the first place I checked and they couldn't find it in a number of different books nor can I find it on line, even at the Ford OEM sites.
  #4 (permalink)
Old 08-16-09, 07:43 PM
Official Member
Could they be the same ones used in the thermostat housing?
  #5 (permalink)
Old 08-16-09, 09:55 PM
COBRA90GT's Avatar
Moderator
It sounds like you are referring to the "coolant crossover pipe" by the alternator, correct? If so, your local Ford parts department can order the o-rings for you (if they don't have any in stock).
If your local Ford parts dept isn't very competent and looks at you sideways when you inquire about said o-rings, try giving Steve at Tousley Ford in MN a call (Google for his info). Or, try any of the other "mustang friendly" Ford parts guys who cater to enthusiasts on the 'stang msg boards...
G'luck.
edit - found the part number via our handy search function:
391533-S100
  #6 (permalink)
Old 08-17-09, 10:41 AM
bdcardinal's Avatar
tree hugger
o-rings are available separate, they are not the same part number as the t-stat o-ring. 391533-s100 should be the part number you are looking for, they go into the head. its a standard part number, not a normal part number if there is any confusion.
Reply
Thread Tools
Display Modes
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
