This is a discussion on clutch problems within the 2.3L (N/A & Turbo) Tech forums, part of the 2.3L Mustang category; The clutch pedal on my 89 has decended. Its lower to the floor than it was. It happened when I ...
The clutch pedal on my 89 has decended. Its lower to the floor than it was. It happened when I drove to Reno from Kalama, WA. It also looks like the trans may be leaking (it wasnt before I left) Im wondering if I have a bad linkage or a more serious problem.
the clutch pedal is probably the stock adjuster has stripped. reach down and pull up on it, it should make a clicking noise and then stay, if it doesn't you need a new adjuster. Personally I would go with a billet quad/firewall adjuster setup.
