Mustang Forums at StangNet
1980 2.3 non-turbo charging
This is a discussion on 1980 2.3 non-turbo charging within the 2.3L (N/A & Turbo) Tech forums, part of the 2.3L Mustang category; I have a non-turbo 80 that has a 2 wire connection to the alternator. Parts store says I should have ...
Go Back   Mustang Forums at StangNet > Mustang Forums > 2.3L Mustang > 2.3L (N/A & Turbo) Tech
Over 151,000 Members!!
Reply
  #1 (permalink)
Old 08-22-09, 05:05 PM
I have a non-turbo 80 that has a 2 wire connection to the alternator. Parts store says I should have a 3rd wire. I had 79-80 2.3's when I was younger and don't remember any more than a 2 wire hook-up. Alternator tests as good, but won't start or run w/o a jump or boost. It will also die at idle after 10 to 15 minutes... any suggestions?
thanks
  #2 (permalink)
Old 08-23-09, 05:45 AM
cjones's Avatar
do you have an external voltage regulator??
if so, let the parts store know this, the 3-wire is with the internal regulator.
have you had the alt and the regulator tested yet??
  #3 (permalink)
Old 08-23-09, 01:19 PM
Ah ha, yes it does. I had the alternator checked, it was ok. When I bought the car the guy I bought it from said he had recently replaced the regulator. I'll try that next.
Thanks
Reply
Thread Tools
Display Modes
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
