Mustang Forums at StangNet
Fuel Pump won't crank.
This is a discussion on Fuel Pump won't crank. within the V6 Tech forums, part of the 94-04 V6 Mustang category; Hi. I have a 1998 3.8 mustang. Car suddenly stopped, and found out that no electricity is going to the ...
Go Back   Mustang Forums at StangNet > Mustang Forums > 94-04 V6 Mustang > V6 Tech
Over 151,000 Members!!
Reply
  #1 (permalink)
Old 08-24-09, 03:37 PM
Hi. I have a 1998 3.8 mustang. Car suddenly stopped, and found out that no electricity is going to the fuel pump. I ran a wire to the fuel pump and the starts it. I changed the Constant Control Relay Module and still don't get power to the fuel pump. Fuses are all good. The only other thing I need to check is the Inertia Switch, but if I still don't get any power what could it be? Can anyone help me please?
  #2 (permalink)
Old 08-24-09, 04:23 PM
Complete the circuit
Check your ground, not for the pump but for the relay module..
I would consider a wiring diagram and jump the connection at the module to see if the wiring going to pump is not damaged. I`m not a big fan of the factory modules myself, much of the time the solder breaks down and they fail.. I`d wire in a standard 4-pole relay, there way cheaper..
Good call on the bypass, most probably would of assumed the pump was bad.
  #3 (permalink)
Old 08-25-09, 09:01 AM
Thanks for your response. I went home yesterday and checked all the wires. From the CCRM, the Inertia Switch, to the fuel pump and found out that I had a peeled wire at the connection at the fuel pump. So glad to be running again.
I have another question. I want to rebuilt my engine pretty soon. It has over 240,000 miles already. Still in okay condition, but anytime soon is going to die. I want to make my V6 the fastest and strongest V6 out there. What should I do besides a supercharger to get more power?
Reply
Thread Tools
Display Modes
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
