Mustang Forums at StangNet
Driver side muffler hanger - tapped holes?
This is a discussion on Driver side muffler hanger - tapped holes? within the 2005 - 2009 V6 Tech forums, part of the 2005 - 2009 (S-197) Mustang category; I've got an '06 Pony-package that I'm about to install the Pypes SFM65 dual exhaust system on. I'll be using ...
Go Back   Mustang Forums at StangNet > Mustang Forums > 2005 - 2009 (S-197) Mustang > 2005 - 2009 V6 Tech
Over 151,000 Members!!
Reply
  #1 (permalink)
Old 08-25-09, 10:48 AM
I've got an '06 Pony-package that I'm about to install the Pypes SFM65 dual exhaust system on. I'll be using a set of GT take-off mufflers. I've got the stock hangers for the mufflers and have made sure that the holes in the hangers line up with the factory mounting points in the frame; but, I've noticed that the driver's side mounting holes are not tapped for screw threads. Is this the case with all '06 V6 Mustangs? If so, I guess I'll need to use a tap set to make the threads. It appears that the stock bolts are M8x1.25 metric. Just wondering if anyone else had run into this?
  #2 (permalink)
Old 08-26-09, 10:34 AM
I got the pypes mid muffler system and ran into same problem. Went down to Lowe's and bought a tap set. And then had no problem.
Reply
Thread Tools
Rate This Thread:
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
