Mustang Forums at StangNet
Absolutely Horrible around town MPG
This is a discussion on Absolutely Horrible around town MPG within the 94-95 5.0 Tuning forums, part of the 94-95 Tech category; For starters I'm running an AEM-EMS. I'm lucky if I see 8 mpg around town. I've pulled fuel and increased ...
Go Back   Mustang Forums at StangNet > Mustang Forums > 5.0 Mustang > 94-95 Tech > 94-95 5.0 Tuning
Over 151,000 Members!!
Reply
  #1 (permalink)
Old 08-26-09, 09:23 PM
toyman's Avatar
Official Member
For starters I'm running an AEM-EMS. I'm lucky if I see 8 mpg around town. I've pulled fuel and increased timing in the low load load cells to maintain a 14.7 AFR running in closed loop. The O2 target error and feedback values are as close to zero as one can get. What I'm interested in knowing is whether or not I should pull more fuel so as to increase the AFR to something in the 15.0 range and set that as the target ratio or if I should be looking elsewhere for a solution. MPG at cruise (70 mph) in mountainous driving averages 18 mpg+ with an AFR of 14.7 target. While those running a TwEECer or something else may have a different way of adjusting AFR it's the end result that I'm looking for. Do you run a 15.0+ AFR at light throttle and cruise speed?
Reply
Thread Tools
Display Modes
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
