Mustang Forums at StangNet
300 hp or more?
This is a discussion on 300 hp or more? within the V6 Talk forums, part of the 94-04 V6 Mustang category; I am rebuilding my 1998 3.8L V6 engine. I want to get 300 or more horsepower out of it. Can ...
Go Back   Mustang Forums at StangNet > Mustang Forums > 94-04 V6 Mustang > V6 Talk
Over 151,000 Members!!
Reply
  #1 (permalink)
Old 09-04-09, 02:44 PM
300 hp or more?
I am rebuilding my 1998 3.8L V6 engine. I want to get 300 or more horsepower out of it. Can anyone tell me what to do it. Supercharger, Cam, Fuel Injectors, Pulleys… What else? Also what would be the best transmission and rear gears for it? If I do all the mods is there anything I need to do with the fuel pump or fuel lines do deliver better fuel? PLEASE HELP
  #2 (permalink)
Old 09-07-09, 01:40 AM
onebadsixxx's Avatar
You can take your current block and make it a 4.2L/4.3L stroker, with a good enough cam and well ported heads and intakes, its a possibility to reach about 250-275rwhp on motor alone. Then add a minor shot of nitrous, and bingo! your 300 horses are at your door.
  #3 (permalink)
Old 09-08-09, 07:30 PM
shine1stang's Avatar
Do you plan on forging your bottom end? or you just doin a stock rebuild? Cam, head, and n2o will def get you there. I would recommend a 255 fuel pump and your lines will be fine. Im running stock lines and putting down low 500s to the wheels right now. As for injectors i believe 36lb injectors should be more than enough for you.
As far as power adder, turbo, sc, or n2o will all get you above 300hp. What about a m90 from the tbird. They can support 300hp. im sure you can find them cheap enough around you.
Reply
Thread Tools
Display Modes
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
