Mustang Forums at StangNet
76 cabra 2 need help
This is a discussion on 76 cabra 2 need help within the MII Discussion forums, part of the Mustang II category; hello a few weeks ago and i came across a problem with my cobra the engine is shifted to the ...
Go Back   Mustang Forums at StangNet > Mustang Forums > Mustang II > MII Discussion
Over 151,000 Members!!
Reply
  #1 (permalink)
Old 09-07-09, 07:45 PM
alan101's Avatar
hello a few weeks ago and i came across a problem with my cobra the engine is shifted to the left! can anyone tell me what some problems could be?
  #2 (permalink)
Old 09-07-09, 08:24 PM
Wart's Avatar
I'm Mad as HELL and I'M not Gonna Take it ANYMORE!
About 1 inch to the left?
  #3 (permalink)
Old 09-07-09, 09:37 PM
alan101's Avatar
1 inch
i would say from 1 - 3 inchs!
  #4 (permalink)
Old 09-08-09, 08:26 AM
That's the way they were manufactured so it is normal... don't worry about it.
david
  #5 (permalink)
Old 09-08-09, 10:46 AM
alan101's Avatar
are you sure because its just it looks like the engine will hit the side of the car when i start it? the pass side!
  #6 (permalink)
Old 09-08-09, 03:17 PM
If my memory serves me well, the engine is offset slightly to the passenger's side. This is a problem most II owner's run into when they try to make a hoodscoop functional. However that said, your engine should not hit the passenger frame rail when you start it up. If it does, then check your motor mounts.
david
  #7 (permalink)
Old 09-08-09, 04:38 PM
alan101's Avatar
could it be a tranny mount? i just redid both motor mounts someone was telling me it could be tranny mount but i thought i would ask someone else first?
  #8 (permalink)
Old 09-08-09, 04:49 PM
Wart's Avatar
Quote:
The 'sides' of the car are determined from sitting in the operators seat. Just so you know.
Take a tape measure/ruler and measure from the frames to the dampener. The engine should be ~ 1 1/8 inches closer to the right frame than the left.
If the trans mount were far off enough to make the manifold hit the frame rale the engine would be noticeably cocked in the frame.
  #9 (permalink)
Old 09-08-09, 05:23 PM
alan101's Avatar
oh ok thanks this is my first car so im learning as i go! but that helps alot so thank you!
  #10 (permalink)
Old 09-08-09, 05:30 PM
alan101's Avatar
trans mount
ok well i just got done and its about 4 inchs closer to the right side?
  #11 (permalink)
Old 09-10-09, 11:34 AM
alan101's Avatar
is there anywere i can find a new trunk lid? the one i have the wing wont stay on to much rust!
  #12 (permalink)
Old 09-11-09, 12:03 AM
COBRAIIW's Avatar
Official Member
Sounds like you reversed the motor mounts, or broke one.
Reply
Thread Tools
Rate This Thread:
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
