Mustang Forums at StangNet
Trouble Accelerating
This is a discussion on Trouble Accelerating within the 2.3L (N/A & Turbo) Tech forums, part of the 2.3L Mustang category; My '89 2.3 4 cylinder is having a lot of trouble accelerating from a standstill or lower gears. I can ...
Go Back   Mustang Forums at StangNet > Mustang Forums > 2.3L Mustang > 2.3L (N/A & Turbo) Tech
Over 151,000 Members!!
Reply
LinkBack (1) Thread Tools Display Modes
  1 links from elsewhere to this Post. Click to view. #1 (permalink)
Old 09-08-09, 04:27 PM
Exclamation Trouble Accelerating...is it the transmission?
My '89 2.3 4 cylinder is having a lot of trouble accelerating from a standstill or lower gears. I can slam down the pedal and still be plodding along at 5 mph, gradually and slowly making it to speed limit. Merging is a nightmare. For some reason, the problem is off and on. After I changed transmission fluid, it went great for about 20 or 30 minutes, and then went back to how it was.
I've tried both slowly pushing the pedal down and slamming the pedal down to the floor. Still goes extremely slow either way. It seems like it's having the most trouble changing from 1st to 2nd gear. Also, the car jolts when I switch from Park to Reverse or Drive. I'm not sure if they are related problems...
Any ideas on what could be wrong?
  #2 (permalink)
Old 09-11-09, 11:19 PM
robbo1987*2.3*'s Avatar
a4lds are junk do a 5 speed swap and it will fix your acceleration problem a little bit put a turbo motor in it and the entire problem is solved
  #3 (permalink)
Old 09-12-09, 11:03 AM
65ShelbyClone's Avatar
Quote:
Assuming the transmission is the problem. We need more information.
Reply
Thread Tools
Display Modes
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
LinkBacks (?)
LinkBack to this Thread: http://www.stangnet.com/mustang-forums/795063-trouble-accelerating.html
Posted By For Type Date
test This thread Refback 09-13-09 08:59 PM
