Mustang Forums at StangNet
Punishable by Death?
This is a discussion on Punishable by Death? within the Classic Talk forums, part of the Classic Mustangs category; I have a 66 Coupe with a 289. The engine appears to be correct for the car; I even have ...
Go Back   Mustang Forums at StangNet > Mustang Forums > Classic Mustangs > Classic Talk
Over 151,000 Members!!
Reply
  #1 (permalink)
Old 09-08-09, 08:48 PM
I have a 66 Coupe with a 289. The engine appears to be correct for the car; I even have the aluminum date code tag, which is attached to the intake manifold. It give a January 1966 build date.
Problem is the engine has been bored .040" over already and may or may not be able to run well with only a hone. I should find out more on that tomorrow.
The heads most likely need machining also.
Problem is I want to get the HP up to around 300 and with the stock heads, intake, exhaust manifolds and the 2 barrel carb that is not likely.
If the block can be used I still need to install aftermarket heads, intake, and exhaust as well as other additional parts.
I wonder if this is a foolish thing to do, since the engine matches this car?
It is a couple, needs paint and seat covers etc. but is not a beat up Mustang. Rust is very limited.
There is a 302 that can be had, rebuilt and fitted with the top parts to get me to where I want to be. As much as I would like to keep the 289 in storage I have no room to do so.
What do think, what did you or others that you know do?
tia
sparx
  #2 (permalink)
Old 09-09-09, 08:47 AM
Official Member
It's your call really, if the 289 can't be just honed and needs to be bored you'd have to step up to .060" which is farther than I would go and I have read of overheating issues going that far. Finding out if it'll take just a hone will be your deciding moment. These engines have lasted >40yrs. with 100's of thousands of miles, they wear out eventually or some PO overboars them or overheats them.
If it can't be saved I have seen other 289's for sale if you want to stay stock CID block or you can swith to a hyd. roller 302 which are bountiful and look the same cosmetically, many also decide to go with a later model roller 302 which are also plentiful. The roller parts are more expensive if you need to replace them (cam, lifters, etc. are ~3X what hyd. are but you don't have to break them in or worry about ZDDP additives).
If you check corral.net classifieds there are always people selling newly rebuilt motors to step up to the next biggest CID for more power so there are some good deals if you trust the seller or hear it run before buying. You might also want to price some crate motor short blocks and long blocks. Often the cost of a crate motor with warranty is the same as a rebuild.
Lots of options.
Jon
  #3 (permalink)
Old 09-09-09, 09:22 AM
Yeah I have a machine shop to visit today that has a 1969 302.
I will have him check the 289 today.
I hear good and bad about crate motors, stories of cylinders bored to different diameters and cheap parts used. Who do you trust?
TY
sparx
  #4 (permalink)
Old 09-09-09, 11:13 AM
krash kendall's Avatar
Official Member
Quote:
sparx
This is a very true statement. That would be demanding more than 1HP per cubic inch. An expectation of half that would be more realistic.
I have one of those 302s that a PO bored .060 over. Yeah, it doesn't do well idling in traffic in the summer. I have an original copper three core that I had rebuilt, but the volume of water the car can hold is low. Also, the '70 302 that I have required the lower pipe to be relocated to the driver's side. I consequently have very little room between the fan blades (factory V8 mustang original) and the rad pipes thereby eliminating the possibilty of a fan shroud. It should be noted that when this car was designed 50 years ago, it was with the view of open road freedom - not sitting in gridlock, as it didn't exist as it does today.
So, although an engine swap can be quite easy, there are the peripherals that can cause a few problems (or opportunities). A larger aftermarket aluminum rad complete with electric fans can be had for what seems like alot of money, but performance-wise may be well worth it depending on the value you place on the idiosyncracies of an old car in today's world versus the dependabilty we often demand and rely on.
But now I am rambling on...
Reply
Thread Tools
Display Modes
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
