Mustang Forums at StangNet
Underdrive Pulleys
This is a discussion on Underdrive Pulleys within the 2010 Mustang forums, part of the Mustang Forums category; I am trying to install my Steeda underdrive pulleys myself, but i can't seem to get the crankshaft bolt off. ...
Go Back   Mustang Forums at StangNet > Mustang Forums > 2010 Mustang
Over 151,000 Members!!
Reply
  #1 (permalink)
Old 09-10-09, 07:46 AM
Underdrive Pulleys
I am trying to install my Steeda underdrive pulleys myself, but i can't seem to get the crankshaft bolt off. I am using a impact wrench and everything and it doesn't seem to budge. I think i need to get it straight on to get the most torque on the bolt. Has anyone put pulleys on there 2010 GT, any insight would be a great help. Thanks.
  #2 (permalink)
Old 09-10-09, 09:06 AM
bigcat's Avatar
start with the upper hole, and if more traction is needed, try the lower hole
if the impact will not remove the bolt, i suggest checking the air pressure to the impact tool (if it is pneumatic) and if that is OK, then get a new impact. the impact you have may not be heavy duty enough to remove the bolt. many times this is because it is an inexpensive impact. they typically do not have the torque to remove stubborn bolts.
  #3 (permalink)
Old 09-11-09, 01:42 PM
Official Member
hmm now that sounds odd conisdering i got my bolt out with a nice 2 foot breaker bar.
if you are a manual ensure you have the car parked in reverse with the ebrake set it stops the motor from turning over on you. for an automatic the good old starter hole trick is the only way and i hate doing it. (remove starte and lock the flywheel with a prybar) hope you figure it out soon
Reply
Thread Tools
Rate This Thread:
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
