Mustang Forums at StangNet
01 squealing noise on acceleration
This is a discussion on 01 squealing noise on acceleration within the V6 Tech forums, part of the 94-04 V6 Mustang category; 01 3.8 AT has a severe squealing noise. Car was hit in the left front and has had steering rack ...
Go Back   Mustang Forums at StangNet > Mustang Forums > 94-04 V6 Mustang > V6 Tech
Over 151,000 Members!!
Reply
  #1 (permalink)
Old 09-12-09, 02:37 AM
01 3.8 AT has a severe squealing noise. Car was hit in the left front and has had steering rack replaced, has whine/squeal that increases on acceleration is very loud. Guy who fixed it says it is air in the power steering, but at idle no noise and even when revving it at idle no noise, typical noisy ps pump.I am beginning to wonder if it's in the transmission or torque converter.It is still there at highway (60-70) mph but is a low noise when it upshifts into o/d. Any ideas, suggestions? It is a pretty bad whining noise.
Otherwise car seems fine and runs fine, all that was fixed was the body work, replacing the rack and pinion, alignment, and ball joint.
  #2 (permalink)
Old 09-13-09, 08:21 PM
Davis83's Avatar
Is it like a screaming noise? Check your cam synchronizer, your cam sensor is connected to it. It's right under your egr. I replaced mine not to long ago and the noise was horrible.
Reply
Thread Tools
Display Modes
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
