Mustang Forums at StangNet
different irs set-ups
This is a discussion on different irs set-ups within the SVT Talk forums, part of the SVT category; whats the difference between the 99-01 irs and the 03-04 irs....
Go Back   Mustang Forums at StangNet > Mustang Forums > SVT > SVT Talk
Over 151,000 Members!!
Reply
  #1 (permalink)
Old 09-12-09, 06:17 PM
crazystang25's Avatar
Official Member
  #2 (permalink)
Old 09-15-09, 12:46 AM
Official Member
The 03/04 IRS has stronger half shafts, and some better subframe stiffening/reinforcing. Honestly, the 99-01 IRS is pretty weak, and wheel hop is a big problem. Using the 03/04 IRS is better, but it still has it's problems.
  #3 (permalink)
Old 09-24-09, 11:48 AM
SVT32VDOHC's Avatar
waiting for the next hack attack
The lower control arms are the same. The hub/spindle assy is the same. The upper control arms, subframe, axle shafts and differanital are different. All the 03-04 stuff is better.
Small cheap upgrades you can do are to change the lower subframe bolts. They have 14mm holes in the bushings and the body, but Ford stuck 12mm bolts in them. I replaced mine and thought it took off a little smoother and stayed straighter. It also cut down on wheel hop.
The number one thing you can do no matter what year your car is...is a sticky tire. Buy some 275 Nittos. My 04 has NO wheel hop after that simple mod. They don't hook the greatest, 1st gear I can rip off with almost 600RWHP, but they make the car driveable that's for sure.
Reply
Thread Tools
Rate This Thread:
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
