Mustang Forums at StangNet
dash insert
This is a discussion on dash insert within the MII Discussion forums, part of the Mustang II category; hey guys, i'm looking for the brushed aluminum dash inserts for the II. i'm changing the color of my interior ...
Go Back   Mustang Forums at StangNet > Mustang Forums > Mustang II > MII Discussion
Over 151,000 Members!!
Reply
  #1 (permalink)
Old 09-13-09, 07:32 AM
dash insert
hey guys, i'm looking for the brushed aluminum dash inserts for the II. i'm changing the color of my interior and i want to put the brushed panels on the instrument cluster part of the dash like the older trans am cars. anbody know where i might be able to find them for the II?
  #2 (permalink)
Old 09-13-09, 09:41 AM
COBRAIIW's Avatar
Official Member
Try ebay, lots of the smaller parts are showing up in the past few years.
  #3 (permalink)
Old 09-15-09, 12:53 PM
78CobraII's Avatar
Moderator
Garage
There's a guy on one of the .NET forums working on fabricating some.
Also, check with the MII parts vendors as they might have some.
The factory "brushed aluminum" dashes are just some kind of film. The ones on my '78 CBII are worn through the finish. These aftermarket guys are making them from real aluminum, so they can be a bit more pricey.
  #4 (permalink)
Old 09-23-09, 02:18 PM
Steel Steeds's Avatar
Official Member
Mine are all real aluminum. I know that some were vinyl, but most were not. The only vinyl ones I've seen personally were on '78 models, but my King has real aluminum.
  #5 (permalink)
Old 09-28-09, 10:08 AM
78CobraII's Avatar
Moderator
Garage
My '78 Ghia Sport has the black "engine-turned" dash insert, and it is an aluminum sheet glued to a steel sheet which in turn mounts to the plastic dash with push through and bend over steel tabs. Pretty durned complicated!
I've assumed that it was done this way because it was such a low production item, and wondered if the original Motor Town produced CB II's weren't done the same way.
Reply
Thread Tools
Rate This Thread:
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
