Mustang Forums at StangNet
New Engine and Tweecer
This is a discussion on New Engine and Tweecer within the Fox 5.0 Tuning forums, part of the 5.0 Tech category; Well it's been a long time since I've tried posting stangnet but after moving to my new house and getting ...
Go Back   Mustang Forums at StangNet > Mustang Forums > 5.0 Mustang > 5.0 Tech > Fox 5.0 Tuning
Over 151,000 Members!!
Reply
  #1 (permalink)
Old 09-13-09, 08:13 PM
bmo37's Avatar
Well it's been a long time since I've tried posting stangnet but after moving to my new house and getting settled in my brother and I have tried to resurrect the beast after about a 2 year down time.
Prior to moving I had the car in the tuning stages, to the point where the engine sounded really rough but was able to start and maintain idle on it's own, after moving we were unable to get her to fire up until recently, after priming the oil pump and playing with the plugs and distributor. It starts but won't idle on it's own (need to pump the throttle to get it to start and hold throttle down to maintain an idle), the exhaust really stinks of gas (chokes you out if your near it for more than a few seconds).
Now I'm assuming I have a really rich condition, but before I can work with tuning and such I need to get the car to somewhat idle to set the base timing. I'm pretty much looking for some advice or guidance from anyone with experience with the tweecer and tuning. Below is some things I'm going to try when I have a chance sometime this week.
CID changed to 347
Neutral and Drive Idle changed to 800rpm
High and Low Injector Slopes changed to 42.5/50.5
MAF Transfer Loaded 42lb pro-m table
Crankfuel PW vs time changed to .432 from 1
Injector Breakpoint set to 1.9
Injector offset vs battery voltage changed
Fuel Table Startup: leaned out by 10% (multiplied by 1.1)
Checksum Base Address: set to 0 (disables error code 15 in eec)
  #2 (permalink)
Old 09-15-09, 07:48 AM
strtrcr50's Avatar
the HIV ct
To start, any codes?
Also, try setting injector breakpoint to 2.500 for all values, and try this injector offset table.
Those are the settings provided with the newest version of binaryeditor for 42 lb injectors.
  #3 (permalink)
Old 09-18-09, 06:51 PM
bmo37's Avatar
thanks for the reply, im going to try it this weekend and see how it goes. going to try doing the basics injector slopes, maf transfer, injector breakpoint, and battery offset voltages.
  #4 (permalink)
Old 09-19-09, 07:44 PM
strtrcr50's Avatar
the HIV ct
If you can get it running ok and datalog it, you could also feed the logs through EECAnalyzer if you have it and try the cam timing it recommends.
Reply
Thread Tools
Display Modes
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
