Mustang Forums at StangNet
1990 Notch eletric fan not working??
This is a discussion on 1990 Notch eletric fan not working?? within the 2.3L (N/A & Turbo) Tech forums, part of the 2.3L Mustang category; Ok car is bone stock 2.3 90" Notch. The stock fan is not working while the engine is running, thus ...
Go Back   Mustang Forums at StangNet > Mustang Forums > 2.3L Mustang > 2.3L (N/A & Turbo) Tech
Over 151,000 Members!!
Reply
  #1 (permalink)
Old 09-18-09, 07:17 AM
ga289stocker's Avatar
Official Member
Ok car is bone stock 2.3 90" Notch. The stock fan is not working while the engine is running, thus it heats up if stationary for to long. I pulled the electrical connector off the fan and confirmed the fan does work as I straight wired it of the battery to test it. My question is where do I go from here to fix it so it will cycle on and off when the car is running? Where is the relay located for these things? Any help is most appreicated.
  #2 (permalink)
Old 09-18-09, 08:44 AM
Red_LX's Avatar
Doubt I could be of much help, unless you need porn pics!!
Location: Morgantown, WV...where couches meet their doom
The factory fan does not come on until the engine gets somewhere in the 240 degree range, which is probably why it's not coming on.
If you have AC, it should come on when you turn on the AC.
If you want it to come on sooner, you'll have to put in your own adjustable temp controller and hook the fan up through it.
  #3 (permalink)
Old 09-18-09, 03:33 PM
Official Member
Interesting, as the a/c unit is not working at this time. And I don't think the car has got up to 240 on the gauge yet. Maybe I'll just let the thing sit and idle for a while and see what happens. Thanks.
  #4 (permalink)
Old 09-18-09, 05:40 PM
My '90 doesn't even have a fan right now. Took it out 2 years ago because it wasn't working. Overheated sitting in a friends driveway running for about 20min, fan never came on. Its made me nervous a couple times but never puked any water.
  #5 (permalink)
Old 10-09-09, 02:05 PM
Cooling Fan Not Working
I have the same problem with my '87 and its the cooling can relay. My a/c doesn't work either and both the fan and the a/c run off of the same relay. Its very hard to find relays for our cars so here's a website where I found them. Try that. And the relay is to the left of the steering column if you were having trouble locating it. Its mounted with one screw. Hope this works out for ya.
'87 mustang cooling fan relay - Google Product Search
Reply
Thread Tools
Display Modes
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
