Mustang Forums at StangNet
Wheel Differential? help
This is a discussion on Wheel Differential? help within the V6 Tech forums, part of the 94-04 V6 Mustang category; Hi i have a 2000 v6 automatic mustang and it needs to replace the wheel differential. Can i put it ...
Go Back   Mustang Forums at StangNet > Mustang Forums > 94-04 V6 Mustang > V6 Tech
Over 151,000 Members!!
Reply
  #1 (permalink)
Old 09-18-09, 10:04 AM
Hi i have a 2000 v6 automatic mustang and it needs to replace the wheel differential. Can i put it a GT one or do i need the whole rear Axle? I know that the gt has a tlock and its a 8.8 axle. i need help. Also can you tell me the advantages and disadvantages if there any. and what year from a gt can i take the gears or axle.
  #2 (permalink)
Old 09-18-09, 10:58 AM
bdcardinal's Avatar
tree hugger
what would be this wheel differential you are referring to? if you are talking about the centre section of the rear axle assembly, then no you cant use a GT one unless you get the whole housing assembly with axles, gears, bearings etc.
  #3 (permalink)
Old 09-18-09, 11:56 AM
yes the centre section where the gears are. They sell me that section for 49.99 and for the whole axle is 84.99. It does not matter if its a gt or v6, the price is the same, so would it be better if i install the gt whole 8.8 axle? is the same price and the gt has a tlock, instead of buying the tlock for the v6, whch it would save me money.
and what mustang years can i take the rear end gearing or the whole axle?
  #4 (permalink)
Old 09-18-09, 12:30 PM
bdcardinal's Avatar
tree hugger
the GT centre section will NOT fit in a V6 housing. you need the housing from a 99-04 GT to be a complete bolt in. if your vehicle has ABS, you need to make sure that the GT axles have the tone rings.
  #5 (permalink)
Old 09-19-09, 05:49 PM
and what years can i take the 8.8 axle of a GT. my car is a 2000 v6 automatic. and does it matter if the GT axle is auto and manual?
Reply
Tags
axle, differential, gears, rear end
Thread Tools
Display Modes
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
