Mustang Forums at StangNet
Ford Windstar Tranny won't stay in Overdrive
This is a discussion on Ford Windstar Tranny won't stay in Overdrive within the Other Auto Tech forums, part of the General Automotive Forums category; Gentlemen and Ladies, I'm tearing my hair out on this one and could really use some help. My 2000 Ford ...
Go Back   Mustang Forums at StangNet > General Automotive Forums > Other Auto Tech
Over 151,000 Members!!
Reply
  #1 (permalink)
Old 09-19-09, 11:07 PM
I'm tearing my hair out on this one and could really use some help. My 2000 Ford Windstar with 165K miles and just passed emissions with flying colors (I run synthentic oil), won't stay in Overdrive. I get on the freeway 3 miles from my house. For the first 10-20 miles, the van runs fine. As the freeway mileage continues, anything above 75 mph makes the van drop down out of overdrive. As the mileage continues, so the does the speed that the van needs to maintain to stay in overdrive. Anything over 74, then 74, and so on down to 60mph and then eventually it just won't stay in Overdrive at all. If I'm driving an hour, it won't go back into overdrive at all, even under 40mph with no throttle.
The trigger to this is if I'm driving 75mph and I click the cruise control to go up 1mph, it should just slowly go faster. As the problem kicks in, it just downshifts and then may or may not go to overdrive. As I continue driving, it just won't go down.
I cleaned the MAF and the air filter. I did a complete tranny fluid change and also checked for codes. No luck. I'll take any other ideas before I pull the tranny.
  #2 (permalink)
Old 09-22-09, 03:41 PM
KBExperience's Avatar
is there an overdrive switch? i'd check that
  #3 (permalink)
Old 09-22-09, 03:43 PM
There is a switch on the tranny stalk on the console. It works normally when the tranny is working correctly. After the tranny starts staying in Overdrive, it won't do anything other than make the light go on and off.
Reply
Thread Tools
Rate This Thread:
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
