The modulator is on the side of the transmission. You have to remove the retaining bolt and pull out the old modulator. There is a pin behind the modulator that you need to keep and reinstall. Don't loose it. Make sure the pin is in place (or still there), push the new modulator on, and replace the retaining bolt.
