Mustang Forums at StangNet
sputtering and cam shaft sensor code
This is a discussion on sputtering and cam shaft sensor code within the V6 Tech forums, part of the 94-04 V6 Mustang category; 98 V6 is sputtering horribly and has a cam shaft sensor code and an ingnition problem code. checked the connection ...
Go Back   Mustang Forums at StangNet > Mustang Forums > 94-04 V6 Mustang > V6 Tech
Over 151,000 Members!!
Reply
  #1 (permalink)
Old 09-24-09, 02:00 PM
ronstang94's Avatar
Official Member
98 V6 is sputtering horribly and has a cam shaft sensor code and an ingnition problem code. checked the connection to the cam shaft sensor and the wires. it looked fine. car has over 100k miles. Do these sensors commonly go out? should I just replace it? or are there some voltage tests I should do on the wires first to make sure its not just a bad wire some where?
Thanks
  #2 (permalink)
Old 10-14-09, 04:15 AM
deff swap the sensor and invest in a new ignition coil as well...should stop the problem
-mike
Reply
Thread Tools
Display Modes
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
