Mustang Forums at StangNet
T-lok
This is a discussion on T-lok within the 2005 - 2009 V6 Tech forums, part of the 2005 - 2009 (S-197) Mustang category; Has anyone installed T-lok in the rear end of the s197 v6? How much and what parts are needed?...
Go Back   Mustang Forums at StangNet > Mustang Forums > 2005 - 2009 (S-197) Mustang > 2005 - 2009 V6 Tech
Over 151,000 Members!!
Reply
  #1 (permalink)
Old 09-24-09, 08:48 PM
The Fang's Avatar
Official Member
T-lok
  #2 (permalink)
Old 09-25-09, 11:15 AM
echo7's Avatar
Official Member
I heard they were very similar (or the same) to the limited slip diffs in Rangers (size wise). Could possibly get one out of a junk yard? I'm not for sure though; was talking with a Ford Mechanic while I was getting some work done.
  #3 (permalink)
Old 10-25-09, 08:10 PM
RNstanger's Avatar
I got mine on ebay new a couple years ago for I think $185. Most places have them for around $200-225. Check ebay first you might get lucky. Plus 2 quarts of royal purple gear oil, 75w140.
  #4 (permalink)
Old 10-26-09, 04:46 PM
V6Vin's Avatar
Garage
Don't forget to add friction modifier (4-8oz.) to keep the clutches from sticking and to work smoothly. Personally I will be installing a True Trac. No clutches to have to replace. It's a little more $, but I don't like the idea of having to keep going back into the rear end.
  #6 (permalink)
Old 10-26-09, 08:10 PM
Yes, I just went through this EXACT decision process myself. I wanted limited slip and steeper gears.
I looked at swapping gears and/or the carrier and it's a bear. And in the end, I still would have a 7.5" rear end. I looked into eaton truetracs as well, but decided to go with the tried and true trac-loc. My one comment re: wearing out, I hear the carbon clutch pack will go 100k miles, or more. I figure after the first clutch pack goes, I'll just load up the carbons.
When I looked at how difficult it is to work on the rear end, I ended up buying a 3k 8.8" out of an '07 GT for $350 delivered. I'll be doing the swap and putting in prothane bushings in the next couple of weeks.
  #7 (permalink)
Old 11-05-09, 06:14 PM
The Fang's Avatar
Official Member
Good to know guys and thanks for the info. Looks like trutrac is twice the price but may be worth the extra.
  #8 (permalink)
Old 11-17-09, 12:03 PM
tlok
a lot of people have the ford LS. even with SC and NO2 kits. it is a good streetable differential. unless you are planning to go racing every staturday I would not spend the extra cash for others. I'd just add the money to changing gears and all the diff bearings. dont forget the labor charge at about $300.
  #9 (permalink)
Old 11-17-09, 06:00 PM
V6Vin's Avatar
Garage
Sure, the T-loc works fine. The question is for how long? I know it depends on how you drive it but even if you drive like grandma it will eventually start to slip. Thats what clutches do, they wear. The true trac will not. I plan on driving my car several hundred thousand miles over the next 40 years. I will do this once and be done. If you aren't putting a lot of miles on you car then the T-loc will be fine, or if you plan on selling it before it needs rebuilt, no problem.
Reply
Thread Tools
Rate This Thread:
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
