Man I completely misread that question...
With the 2" drop spindles, the spindle is located 2" higher on the kingpin(?), so yes, there should be more space between the upper inner lip of the wheel and the upper A-arm.
However the lower lip of the wheel will also be 2" higher, so now you may have clearance issues with the lower A-arm or steering arm or something else.
Several MII owners have cut back the lips of the upper A-arm to increase clearance with wheels, and some have installed tubular A-arms for the same reason.
